* * * * * 2 votes
My 1968 John Deere 110
682 replies to this topic
#346 Trav1s ONLINE
Trav1s
  • 3,569 Thanks
  • 4,544 posts
Posted November 01, 2013 - 11:09 AM
Here is the location of the information I have been posting.  Are you looking in a different place?
Travis do you have this back belt guide kit on your deck cover mine does not have it and you cant order it now, maybe I can make one, helps keep the belt on the deck back pulleyattachicon.gif MP2573_________UN01JAN94.gif
I am not sure about the belt guide as I have not removed the belt cover yet.
Edited by Trav1s, November 01, 2013 - 11:10 AM.
  • Navy Chief said thank you
#347 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 01, 2013 - 09:06 PM
The belt guide is on top of the cover by the outside pulley, mine does not have it and its no longer carried. It looks like it would help keep the tractor belt from coming off the mower deck pulley, maybe I can make one.
Also I found out that I was using the wrong S/N, your correct that's the belt I need.
THX
  • Trav1s said thank you
#348 Trav1s ONLINE
Trav1s
  • 3,569 Thanks
  • 4,544 posts
Posted November 01, 2013 - 09:32 PM
Cool!  Glad I could help get this figured out.  I thought the pic would help.
#349 Trav1s ONLINE
Trav1s
  • 3,569 Thanks
  • 4,544 posts
Posted November 02, 2013 - 03:02 PM
Travis do you have this back belt guide kit on your deck cover mine does not have it and you cant order it now, maybe I can make one, helps keep the belt on the deck back pulleyattachicon.gifMP2573_________UN01JAN94.gif
My deck does NOT have this piece.  I don't ever recalling this on any 100 or 200 series tractor I have used or looked over.  It looks pretty simple to make.
#350 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 02, 2013 - 05:17 PM
It looks like it would help keep the main belt from coming off like mine did at first
Looks like one of those small boat rope hooks would work
Edited by Spain, November 02, 2013 - 05:27 PM.
#351 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 02, 2013 - 05:25 PM
Today put 2nd coat of JD buff on mower deck, ready to start painting JD Yellow.
Had some SUCCESS TODAY, installed the Ignition switch, I found out that this set up from JD to change it to a coil ignition vice the magneto has the wiring set up different from the JD 1971 and 1972 ignition coil wiring diagram, it now starts first time and shuts off SO HAPPY!! :wave:
Working on installing side hood flanges and grill then hood
I have to grease all the under Neath mechanisms and change the transmission oil
Im on the down slope now guys!!!
Edited by Spain, November 02, 2013 - 05:31 PM.
  • Trav1s and SupplySergeant have said thanks
#352 Trav1s ONLINE
Trav1s
  • 3,569 Thanks
  • 4,544 posts
Posted November 02, 2013 - 05:56 PM
Glad you got that wiring figured out.  I am going to try to go original (magneto) on the 110 since it is an early production machine.  This thread has been very helpful to me too.
#353 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,010 Thanks
  • 1,090 posts
Posted November 02, 2013 - 07:55 PM
Way to go! Persistence does pay off.
#354 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 03, 2013 - 06:55 PM
Put in some time on the Deere today, installed hood side frames, installed grill and JD grill, installed hood and new crome hood bolts (looks awesome)
Applied first coat of JD Yellow on mower deck
  • Texas Deere and Horse and Trav1s have said thanks
#355 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,010 Thanks
  • 1,090 posts
Posted November 03, 2013 - 07:23 PM
Ummm... wanna do mine next? That looks great!
#356 Texas Deere and Horse OFFLINE
  • 14,873 Thanks
  • 15,513 posts
Posted November 03, 2013 - 09:19 PM
Boy, that 110 is sure looking nice. Next time I run over to Houston, I may have to look you up and come by to see it in person. Very NICE!!
#357 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 03, 2013 - 09:40 PM
Im trying! Maybe I will find another to restore after this, I know all the tricks now
  • Texas Deere and Horse, lyall and Trav1s have said thanks
#358 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 03, 2013 - 09:47 PM
Great job you did there
one great looking 110
it looks to good to use now
you have to get another 110 for everyday use
  • Trav1s and Navy Chief have said thanks
#359 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 04, 2013 - 08:16 PM
Found out that the Mower belt was a NAPA part too short, Grandpa added an "S" hook on the spring to adjust the tension of the short belt, Im ordering the correct one from JD, THX Travis for the P/N
#360 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted November 05, 2013 - 06:04 PM
Disappointment today!  Deere has been starting first time everytime and I start it every day, today it wont start, I have a spark, and at  least gas going to the filter dont know if its making it past the external shut off valve but I see none on the spark plug when I full choke, looks like the carb is acting up again I assume. Guess I will tear the carb off again and use my new rebuild kit I bought from JD
Edited by Spain, November 05, 2013 - 06:06 PM.
