* * * * * 2 votes
My 1968 John Deere 110
682 replies to this topic
#316 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 18, 2013 - 10:58 PM
The only problem is the dust that gets on it while painted, I have no lint free area, I wet sand in between each coat.
  • SupplySergeant said thank you
#317 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 18, 2013 - 11:03 PM
Hood has came along way, lots of repair
Edited by Spain, October 18, 2013 - 11:04 PM.
#318 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 19, 2013 - 02:00 PM
Tore apart mower deck today and pressure washed, doesnt look too bad, has some bogus parts
Edited by Spain, October 19, 2013 - 02:01 PM.
#319 Trav1s OFFLINE
Trav1s
  • 3,571 Thanks
  • 4,544 posts
Posted October 19, 2013 - 02:34 PM
That deck looks really good.  Are you going to go through it too?
#320 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 19, 2013 - 02:40 PM
Going to remove corrosion prime and paint and new stickers
#321 1971Deere OFFLINE
1971Deere
  • 48 Thanks
  • 66 posts
Posted October 19, 2013 - 03:20 PM
I used POR-15 On the bottom of the deck, Seems to hold up better in use, and easier to touch up.
  • Navy Chief and SupplySergeant have said thanks
#322 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 19, 2013 - 03:41 PM
yes I was going to prime and paint the bottom black not yellow as you
#323 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 20, 2013 - 09:07 AM
Does any one have the JD parts manual for the mower deck? I need to order some parts. THX
#324 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,010 Thanks
  • 1,090 posts
Posted October 20, 2013 - 01:05 PM
 Try the online parts listing, here http://jdpc.deere.co...PageServlet_Alt
  • Navy Chief said thank you
#325 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 20, 2013 - 04:56 PM
Ordered from HAPCO  new mower deck wheel bolts and bushings and mower deck sticker kit.
  • Trav1s said thank you
#326 Trav1s OFFLINE
Trav1s
  • 3,571 Thanks
  • 4,544 posts
Posted October 20, 2013 - 05:21 PM
The stuff from Hapco is good!
#327 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 21, 2013 - 07:48 PM
Sanded corrosion off mower deck cover today, will clean up tomorrow some more then prime, had to take it all the way down, bad paint and surface corrosion under paint.
After I finish cover will do the same on the deck
Edited by Spain, October 21, 2013 - 07:48 PM.
#328 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 22, 2013 - 06:44 PM
Worked corrosion removal again this evening a lot more to do
#329 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 23, 2013 - 08:01 PM
Received my HAPCO Deck parts today, man that was quick, still waiting on the JD parts to come in.
#330 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted October 24, 2013 - 06:06 PM
A lot of work, finished sanding the lid and primed, worked on bottom section still have more to do on it.
Edited by Spain, October 24, 2013 - 06:18 PM.
