* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#256 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 03, 2013 - 08:39 AM
Bummer,
No spark at all now on the spark plug when placed touched to block? The condenser as stated above was a kit one which comes with a wire kit not showed for my model in the parts manuals, I assume it doesn't work correctly, wrong power of not enough ohms or power don't know, I guess it could also be coil gone bad.
The only good thing is I have clean gas and gas is getting into the cylinder chamber now.
#257 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 03, 2013 - 10:37 AM
Re checked point gap its tight at.020 per manual.  I ran a "HOT" wire to the resister block and cranked engine, I got such a powerful spark off the spark plug against the block it shocked my hand thru the insulated pliers, the good news is the points and condenser and coil is good!!!
Now I don't know what's causing "NO POWER" to the resistor block from the wire harness; ADVICE Please?
Remember I ran a new power wire, maybe I need to  hook it up somewhere else? or is it the ignition switch?
Im going to try to start it with the Hot wire later, just to run the engine and set the carb idle
Edited by Spain, October 03, 2013 - 10:37 AM.
#258 dropped82 ONLINE
dropped82
    Nut Case
  • 2,665 Thanks
  • 1,876 posts
Posted October 03, 2013 - 10:46 AM
I think you answered you own question. If you have a new wire from the switch to the block then the switch is the only thing left in the system. Just check to be sure your getting power to the switch. If so then replace the switch.
Eric
Sent from my SPH-D700 using Tapatalk 2
  • Trav1s and Navy Chief have said thanks
#259 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 03, 2013 - 11:18 AM
Can I connect it to another wire off the ignigtion switch?
#260 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 06, 2013 - 05:12 PM
Started it today with the hot wire, ran good at first than died, then would only crank with starter fluid, I think the gas is still bad from the rust remover even though I cleaned the tank with gas rinse, gas didn't even smell like gas, I drained it and will have to clean tank again.
Still haven't figured out the " NO Power" to resistor issue
Tomorrow going to clean out gas tank again and clean carp out again, even if I can run it with the hot wire, I can get the carb settings set up right and run it for a while.
Edited by Spain, October 06, 2013 - 10:56 PM.
  • Trav1s said thank you
#261 dyt4000 OFFLINE
dyt4000
  • 17 Thanks
  • 74 posts
Posted October 06, 2013 - 06:40 PM
Just get a test light and start working your way back...
  • Navy Chief said thank you
#262 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 08, 2013 - 04:27 PM
Applied last coat of primer after a wet sand, and applied first coat of JD green
Attached a pic of the hood before it was repaired, looks a million times better
Edited by Spain, October 08, 2013 - 04:32 PM.
#263 lyall OFFLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted October 08, 2013 - 11:05 PM
great job on the hood
I got 3 hoods that I need to fix
trying to locate a good hood so that I can make a plaster cast of it, so that I can fix them
#264 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 10, 2013 - 06:21 PM
Deep cleaned gas tank again washed out with several tanks and swished gas looks good now
Cleaned carb set up per OEM manual, installed now fuel is running out the front when gas valve turned on, just cant get one foot in front of the other, (now I have to figure this out) Im glad I got gas before I wasn't getting any now I have too much
Wet sand and applied 2nd coat of JD green to hood
I still don't know where to begin on the now power tot he ignition system issue.
#265 dropped82 ONLINE
dropped82
    Nut Case
  • 2,665 Thanks
  • 1,876 posts
Posted October 10, 2013 - 07:19 PM
I would replace the ignition switch. Sorry I didn't have one for you. Check ebay, I'm sure there is something on there. If you have power to the switch but nothing after then the switch is your culprit.
Eric
Sent from my SPH-D700 using Tapatalk now Free
#266 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted October 11, 2013 - 08:12 AM
Eric
I would agree with Eric.  IIRC my ignition switch was less than $15.  I wonder if I still have the old one...
#267 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 11, 2013 - 09:45 AM
The engine will crank, it just doesnt provide power to the ignition system and the wiring diagram sucks
#268 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 13, 2013 - 02:34 PM
Figured out carb issue float jet was sticking fixed that adjusted float per manual.
HOT wired ignition from battery to resistor block, "Had to use starter spray" got it started, adjusted carb high and low idle, sounds good low and high power.
Disconnected hot wire, it wouldn't shut off, turned off ignition switch it wouldn't turn off, put choke on it finally shut off. (I don't know how it could keep running with the hot wire disconnected?)
Also just a note, I had to put the choke off and the power lever near idle with the started spray to get it to start
1. So my issues are No power to resistor block going to order ignition switch
2. Engine wont start without started spray? I have to figure this one out
Edited by Spain, October 13, 2013 - 02:42 PM.
#269 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted October 13, 2013 - 05:17 PM
Part 2 today, Saw on line forums which stated don't to use starter fluid due to it will burn a hole in the piston, they rccm you use B12, it worked I started it I also added "Seafoam" to the gas and ran the engine like 15mins, the online forum said that being its running the seafoam will clean out the carb and jets as its running.
Im wondering if something is wrong with my carb it will not start on its on with out help
Note I also noticed the AMP meter shows nothing, maybe because ignition switch is bad.
#270 lyall OFFLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted October 13, 2013 - 06:29 PM
check with your JD dealer first on the ignition switch
I have found out the parts for JD dealer are sometimes cheaper than E-Bay or any other place
got a ignition switch from a JD dealer and it was cheaper the any other place and it fits right
the others I looked at were larger and would have to drill out the hole for the switch
