* * * * * 2 votes
My 1968 John Deere 110
678 replies to this topic
#151 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 01, 2013 - 10:39 AM
I'm pleased that the paint is coming out fairly close to the original JD color, if you look at this pic, it has my OLD deck lift arm with the original JD paint on it next to my repainted color, not bad Id say
  • JDBrian said thank you
#152 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted June 01, 2013 - 11:33 AM
You did match ti pretty close, nice job. :thumbs:
Can't wait to see it all finished. :D
#153 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 02, 2013 - 09:24 PM
IMG_0045.JPG IMG_0357.JPG Before and after console with the tank padding that Rev sent me, I spent today cleaning the components that go iside the console
Edited by Spain, June 02, 2013 - 09:27 PM.
#154 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 02, 2013 - 09:57 PM
IMG_0051.JPG IMG_0355.JPG More before and after console
#155 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 04, 2013 - 07:39 PM
Today I installed the front hood hinges and the front grill. I also put the new JD center console sticker on and the on off switch sticker
Man that big sticker was hard to get in the right place I have some real small air bubbles
#156 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted June 04, 2013 - 10:25 PM
This project has been awesome to follow.  Can't wait for the day when you show us the finished product!  Keep up the good work. What are your plans with "Dewey"? tractor shows? or putting him back to work?
  • Navy Chief said thank you
#157 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted June 05, 2013 - 12:09 PM
He sure "dewey" look good.  :smilewink:
#158 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 05, 2013 - 01:09 PM
Mow the yard with him!! BAck in service he use to mow probaly about 5 acres on my Grandpas Oklahoma ranch, my yard 1/4 acre but I will look good using it!!
#159 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 05, 2013 - 01:13 PM
Note you have to watch some of these Ebay people, I wanted to make sure that a PTO cover was going to fit mine the guy said give me your S/N and tractor Model, I did and he said it would fit, once I received it, it was the wrong one. Hes refunding me but I had to pay $11 to send it back, he said no postage refund, I told him its your fault you said it would fit.
Same thing happened to me on that lift mechanism, guy said it was for my tractor found out it was not and would not
#160 dropped82 ONLINE
dropped82
    Nut Case
  • 2,495 Thanks
  • 1,816 posts
Posted June 05, 2013 - 02:35 PM
Depending on what PTO cover you need I have one. PM me.
Eric
Sent from my XT897 using Tapatalk 2
#161 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 05, 2013 - 02:43 PM
The tractor is really coming along. The paint looks good to me. I used Tremclad JD Green on my 314 which I think is the brand name used for Rustoleum in Canada. I found it was a pretty good match to the JD green on my 2008 2320. It also went on smooth and has a nice gloss to it.
#162 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 05, 2013 - 03:04 PM
Brian, I used the Rustoleum it Matches almost the same as the original. The only thing I dont like about the Rustoleum is the can has the small spray nozzle vice the bigger one that comes on their normal paint, normal paint nozzle easier to spray and you cant interchange them. Also with the Rustoleaum you cant come back and touch up, it leaves a distintive new paint blouch doesnt blend in, have to repaint the whole area not to notice it
#163 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 06, 2013 - 02:18 PM
Installed new JD dash sticker, installed throttle and choke arms, installed and painted gauges and blank off buttons, Installed Steering column and hardware and steering wheel, the o ring that I bought for the JD cap from JD is too small cap want stay snug, they charged me $3.00 for it and I ordered it per parts manual.
Working on getting the wiring harness back in.
Edited by Spain, June 06, 2013 - 04:35 PM.
#164 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 06, 2013 - 07:07 PM
Got the wiring harness reinstalled, does any one know what is suppose to connect to the empty slot on the key ignition switch? The right slot is empty.
#165 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted June 10, 2013 - 02:32 PM
I finally won the bid and got the headlight blank off plate
Edited by Spain, June 10, 2013 - 08:29 PM.
  • Trav1s said thank you
