Modern Gt Fel Build.
103 replies to this topic
#91 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted October 22, 2013 - 11:02 AM
Thanks! That's what I'm still playing with. I have higher holes in the bucket just tried the lower one's. I might make a scissor style link to attach it higher.
#92 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted October 22, 2013 - 01:36 PM
Most of the design looks good except for the bucket, hinge points . Bucket shell shouldn't be square at the rear, you loose your cylinder clearance and roll back, and dump as well. The pic is of a quicky drawing to give you an idea. If I had it all drawn on cad I could give you all the details.
Edited by skyrydr2, October 22, 2013 - 01:39 PM.
#93 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted October 22, 2013 - 04:26 PM
Yeah at full dump position the bucket hits the arms. The bucket was a quick after thought lol gonna build a new one.
#94 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted October 22, 2013 - 06:08 PM
I decided to also redesign the levers
  • twostep said thank you
#95 bigge61 OFFLINE
bigge61
  • 100 Thanks
  • 59 posts
Posted January 05, 2014 - 01:31 AM
Well done, I have been procrastinating my fel build for TOO long!  Looks like you have inspired me to kick it into high gear the MF 1655 is begging me!
  • twostep, chaentjens and michael.kitko have said thanks
#96 OldBuzzard OFFLINE
OldBuzzard
  • 7,026 Thanks
  • 4,792 posts
Posted January 05, 2014 - 04:28 AM
I just watched your "First Drive/Lift" video and have a couple of suggestions.
First, fluid fill the tires and add wheel weights.  That will help with traction.
Second, I noticed that you have single action lift cylinders. That really limits you as to what you can do with a FEL.
I bought a Bolens 1886 with a home made FEL and the builder used single action cylinders, and I truly hated them.
I final got around to having them replaced with double action ones, and now with down pressure on the bucket, it makes a world of difference.
Looks like you have done an awesome job of building that though.
Edited by OldBuzzard, January 05, 2014 - 04:28 AM.
  • chaentjens said thank you
#97 FixItCharlie OFFLINE
FixItCharlie
  • 539 Thanks
  • 344 posts
Posted January 11, 2014 - 10:34 AM
What you have built looks excellent & I understand the design problems with making the needed correction. I have done that myself many times. Now a question / suggestion from some research & being around larger tractors with FEL have you checked on the weight capacity of the front end of your tractor. After watching the video & seeing the reaction of the front wheels you may want to look at some upgrades to them. I have looked at the P. F. Engineering web site & there is a section making the spindles, wheel bearings, & wheels stronger to handle the extra weight added by a FEL.
Charlie
  • KennyP and chaentjens have said thanks
#98 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted January 16, 2014 - 06:47 PM
Thanks guys! I have been heavily using the loader now! I keep finding more and more to use it for! I do have double acting cylinders so no problems there. I have recently filled the rear tires and it made a huge difference. I also have 160 lbs of suitcase weights on the back. I have moved a lot of things with this (snow is fun now lol) the heaviest so far has been three 18" long 32" diameter Unsplit red oak with zero problems. The electronic steering gets a little heavy with full load but still adequate. I'm thinking about taking a front 4x4 axle from a kubota gr series and converting this. Moohoohaha P.s. my next project is a log skidder attachment! Sent from my SPH-L900 using Tapatalk
Edited by chaentjens, January 16, 2014 - 06:53 PM.
  • michael.kitko and crabhab have said thanks
#99 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted January 16, 2014 - 06:48 PM
I will get some more pics and videos up soon!
  • olcowhand and twostep have said thanks
#100 64CubCadet OFFLINE
64CubCadet
  • 3 Thanks
  • 6 posts
Posted January 16, 2014 - 10:24 PM
Sweet project. You have to agree that all the "engineering" a guy does in his head it can be frustrating to iron out the kinks. In the end its all worth it, for some reason I think the grin on your face at the end when all done makes up for any head scratching that it took to get right. Besides all that how many of your neighbors have a GT with a loader? :dancingbanana:
  • michael.kitko said thank you
#101 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted January 16, 2014 - 10:31 PM
I agree!! I was cleaning up snow and had 4 people stop and ask about it!
#102 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted January 17, 2014 - 06:39 AM
Been following your build from the start , glad it's working out great for you , you do nice work so may I make a suggestion for a possible next project , A removable snow blade for plowing snow like what was a factory option on my PK , all you do is unpin the bucket drive over the snowplow frame , bottom loader arms pin to the frame , the one dump cyl gets pined to the snowplow frame and other swings down and is used for the blade angle . You can plow like a normal blade but because it will lift high it makes piling snow easier . On mine the po widen the blade for 4' to 6'
http://gardentractor...king-snow-plow/
#103 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted January 17, 2014 - 02:23 PM
Thanks! Yeah that would work great! That's a nice setup! Sent from my SPH-L900 using Tapatalk
Edited by chaentjens, January 17, 2014 - 02:24 PM.
#104 oifla OFFLINE
oifla
  • 6 Thanks
  • 14 posts
Posted January 20, 2014 - 11:56 AM
coming along nicely, good work
