Modern Gt Fel Build.
103 replies to this topic
#76 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,540 posts
Posted June 18, 2013 - 10:16 PM
They look like they should dig pretty good!
#77 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 19, 2013 - 07:34 PM
Got my cylinders!
Got some of the tabs made and mounted.
I should have more done tomorrow.
Until then.....
Sent from my SPH-L900 using Tapatalk 4 Beta
#78 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,540 posts
Posted June 19, 2013 - 09:47 PM
Where did you get the cylinders, price, spec's?
#79 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 20, 2013 - 04:44 AM
I got them at baileynet.com.
The boom cylinders were $92 a piece. The bucket cylinders were $96 a piece. They are 1.5" bore, 3000 psi, 1" rod diameter, 5300 lbs column load. 3/4" pin diameter. They're called cheif ld welded series.
  • twostep said thank you
#80 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 20, 2013 - 04:46 AM
Heres a page.
#81 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 21, 2013 - 06:37 PM
Here's another small update.
I got the corner gussets/piston mounts made and tacked in. I have both pistons mocked up awaiting the lines and the bucket. I will be picking up the steel tomorrow for the bucket. Until then enjoy!
#82 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 22, 2013 - 04:57 PM
Got the bucket fab started today plus started finish welding the main brackets! Of course I ran outta gas for my welder! No more till next week.
#83 vbob OFFLINE
vbob
  • 3 Thanks
  • 14 posts
Posted August 14, 2013 - 06:49 PM
I do believe that a update is about due, I'm dying here! :poke: :D
#84 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted August 15, 2013 - 05:20 PM
I know! I've been working crazy hours.uploadfromtaptalk1376605186833.jpg uploadfromtaptalk1376605199875.jpg
Only thing left is hard lines.
#85 Cvans ONLINE
  • 7,456 Thanks
  • 6,466 posts
Posted August 15, 2013 - 09:34 PM
Just a suggestion. I think your going to want your bucket to tilt down more while your still working on it. When you have the loader raised you won't be able tilt it far enough to dump it. I am in the process of correcting this fault on my large tractor now and it's turning into a job.
#86 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted August 15, 2013 - 10:37 PM
Yes agreed, I will have to get updated pic of what I did for that. The bucket drops much more than this pic shows .I ended up moving the upper mounts to fix that.
#87 welderman85 OFFLINE
welderman85
  • 38 Thanks
  • 53 posts
Posted August 29, 2013 - 05:37 AM
Great work
#88 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted October 19, 2013 - 07:13 PM
Hello all!
It's been a while. Life has it's trials lol.
So here is an update! This is all done minus two back ordered hoses!
That's the manifold I machined for the hydraulic distribution.
A shot of the attached lines and routing.
A shot with the hood on.
Hopefully next week I will post a video!
  • olcowhand, Texas Deere and Horse, twostep and 1 other said thanks
#89 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted October 22, 2013 - 09:11 AM
As promised, the inaugural run!
I still have to adjust the hydraulic speedsand make a few more changes to the bucket design.
#90 Texas Deere and Horse OFFLINE
  • 14,896 Thanks
  • 15,517 posts
Posted October 22, 2013 - 09:24 AM
Great looking loader!! I do want to ask why you mounted the tilt cylinders so low on the bucket, it would have a lot more tilt leverage and a slower more controlled action on the bucket with them mounted higher from the pivot point.
