Modern Gt Fel Build.
103 replies to this topic
#16 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted March 31, 2013 - 04:09 PM
I'll add this my Ark Loader uses one upright for the reservoir And the quickway loader uses only one also
#17 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted March 31, 2013 - 05:03 PM
Yeah I definitely double checked all that! The hood fully opens, I can easily reach my oil filter and drain and pump. Yeah once the system is bled one should be enough, but I'm concerned about temps. Maybe I'll have to run an oil cooler.
Sent from my SPH-L900 using Tapatalk 2
#18 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted March 31, 2013 - 06:22 PM
What's the capacity of your upright? Piston sizes? I'm curious having one side would be easier. I'm going to be running a 6gpm 2500 psi pump to support my pistons. I'm worried about temps.
Never noticed overheating on my system, I also don't know the GPM of pump either, just know it works. :smilewink:
I'm thinking 6 GPM @ 2500PSI is overkill for a GT loader, and would be concerned about jerking movements, and slamming the cylinders.  Besides,hydraulics live longer at and below 2000psi. :thumbs:
#19 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted March 31, 2013 - 06:29 PM
I've been doing some research and I think your right! Going to go with a 4.5 gpm 2k psi @ 2k rpm and 2.5 to 2.7 at 3600 max rpm 4k. I will be running a control valve with an adjustable pressure relief. I'm going to start off with no oil cooler and see what happens. I will leave a place for one just in case.
Edited by chaentjens, March 31, 2013 - 06:32 PM.
#20 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted March 31, 2013 - 06:42 PM
You are really making some progress on it. I will note like the others that on my fel only one upright is the reservoir and no problems with the temps or running out of oil. My problem is I need a new control valve.
#21 Terryt OFFLINE
Terryt
  • 18 Thanks
  • 14 posts
Posted March 31, 2013 - 08:27 PM
Looks like a great build looking forward to pictures of finished project.
#22 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted April 07, 2013 - 10:29 AM
What size steel are you using for the uprights and arms and what thickness?
#23 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted April 07, 2013 - 10:56 AM
The uprights are 4x4 by 1/4" wall. The arms are going to be 2x4 by 1/8" wall.
  • whigden said thank you
#24 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted April 07, 2013 - 11:00 AM
That's some seriously strong steel you're using.  I used the same thickness steel for my loader arms, and not sure, but I believe thicker for my towers as well.  Better to go on the heavy side than too thin I say.
#25 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted April 07, 2013 - 12:09 PM
I was thinking of using 3 x 3 x 3/16 and 2 x 2 x 3/16 seems strong enough to me?
#26 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted April 07, 2013 - 12:56 PM
Lol! I don't want to worry about ever breaking! Those sound decent size. I would personally go with a 2x4 for the vertical strength on the arms.
#27 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted April 07, 2013 - 01:38 PM
I agree on the rectangular steel for the arms.
#28 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted April 08, 2013 - 06:06 AM
Pretty sure that those PF engineering plans use 2 x 2 for the arms.  I agree that you can´t build it strong enough though.
#29 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted April 09, 2013 - 06:16 PM
Have a small update. Work is crazy. Started the arms, I machined some weld in bushings today with steel outers and oil impregnated brass inners. I'm going to be using 3/4" sst bars for pivot pins.
I have the upper towers capped and opened up for the arms.
Now I'm waiting for the new pump and 4 spool valve to finish the frame fab. I also have to pick up more steel for the rest of the project.
  • olcowhand and boyscout862 have said thanks
#30 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted April 13, 2013 - 06:33 PM
Got my spool valve and filter yesterday from the brown santa.
got the pivots on the upper arms in and the uppers temporarily in.
