Wright Chain Saw Info Needed
3 replies to this topic
#1 MH81 OFFLINE
  • 29,979 Thanks
Posted March 10, 2013 - 10:06 PM
I picked up a well used Wright c-50 chainsaw and finally took a few minutes today to look it over.
No spark at all, so after figuring out the flywheel nut was left handed, I did the needed points cleaning and whatnot.
Now that I have a good, hot spark... The carb seems to be doing the "blow-n-suck" routine.
Does anyone have any info on wright chain saw carbs... Specifically, exploded views or things not to do.
This one is not mine, but a much cleaner version of what I was looking at. Forgot the camera in the house.
My muffler is a little different, but that's the only visible difference
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,800 Thanks
  • 5,097 posts
Posted March 10, 2013 - 10:23 PM
If any two-stroke engine is doing a suck-and-blow, it could be a bad reed valve.  Pull the carb off and check the reed.  Also make sure the muffler is not plugged with carbon from too rich of a mixture.
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted March 10, 2013 - 11:55 PM
I was brave enough to pull the muffler... It's less of a muffler and more of a small resonance chamber, and it was clear.
I am currently out of carb cleaner and I will pick some up Monday or Tuesday. Hopefully mid week, I can get a few minutes to work on it.
#4 Sam OFFLINE
Sam
  • 71 Thanks
  • 174 posts
Posted March 17, 2013 - 07:19 PM
Rebuild kits are available for the Carter ND carb, if all else fails it might be worth a punt.
