Sears Ss16 Brake Band
have to replace
6 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,831 Thanks
  • 2,815 posts
Posted March 10, 2013 - 05:31 PM
well the weather was gorgeous today, and i took my ss16 out of the shed to clean it up. This is where the problem comes in. I brought it up the garage and when i went to stop, I had no brakes!! I got underneath and saw the band/brake lining hanging out.
Here's the question ??
How do I change It? It looks like I have to pull the axle down to get the screw in the side of the rear.( I am looking at the spare rearend) Is there an easier way? any suggestion would be greatly appreciated
Edited by TomLGT195, March 10, 2013 - 05:31 PM.
  • iron Mike said thank you
#2 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 11, 2013 - 08:48 AM
There is no easy way to do it. You will have to drop the rearend to get the old one out and new one in.
  • MH81, iron Mike and TomLGT195 have said thanks
#3 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 11, 2013 - 09:07 AM
BHTS hit the nail, have to pull rear end out to get to it properly. I would drop rear with rear hitch plate attached. I believe McMaster Carr or Graingers carry the brake liner material and the rivets. I think it was Larrybl I bought an extra piece he had last year, maybe he can tell you where he got it. You can use rivets to hole it, I have also seen guys use a thin layer of JB Weld to attach it.
Edited by TAHOE, March 11, 2013 - 09:08 AM.
  • TomLGT195 said thank you
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,831 Thanks
  • 2,815 posts
Posted March 11, 2013 - 03:32 PM
yes I've seen that on vintage sears tractors website. they had a link stating those as suppliers.
thanks again  looks like a big  job this weekend.
#5 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 11, 2013 - 04:04 PM
I will check but should have a good brake band allready off just send me a pm.
#6 TomLGT195 OFFLINE
TomLGT195
  • 3,831 Thanks
  • 2,815 posts
Posted March 20, 2013 - 03:33 PM
well i replaced it, boy what a chore. it took about 5hrs. a friend had a brake band, which turned out to have a rotted strap but the brake liner was good. rerivited it into my strap. i used aluminum as the original were brass. i haven't  adjusted it yet but its in.
#7 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted March 20, 2013 - 06:51 PM
Glad you got it fixed.
