Simple Way To Wire Alternator?
electrics battery alternator wiring
7 replies to this topic
#1 MR Simplicity 6111 OFFLINE
MR Simplicity 6111
  • 14 Thanks
  • 44 posts
Posted March 10, 2013 - 04:16 AM
Hello all,
I am looking for a simple way just to charge my battery from the alternator? I am confused by the manufacturers method.
Thanks
Edited by MR Simplicity 6111, March 10, 2013 - 04:52 AM.
  • larryd said thank you
#2 Michiganmobileman OFFLINE
Posted March 10, 2013 - 05:44 AM
Not sure what you are working with engine wise but heres a generic for starter gens:
And one for an A/C output
Hope this helps
  • MR Simplicity 6111 and larryd have said thanks
#3 KennyP ONLINE
  • 34,220 Thanks
  • 43,339 posts
Posted March 10, 2013 - 06:20 AM
Knowing which alternator you are talking about will help. Is it an automotive type? Or the one built in the engine? If so, what engine is it?
#4 MR Simplicity 6111 OFFLINE
MR Simplicity 6111
  • 14 Thanks
  • 44 posts
Posted March 10, 2013 - 06:26 AM
Sorry, i forgot to mention that. It is the alternator built into a 12hp Briggs. Thanks
  • KennyP and larryd have said thanks
#5 Michiganmobileman OFFLINE
Posted March 10, 2013 - 06:39 AM
The last diagram I posted is for my 16HP briggs with the internal ac alternator for lights and dc output for charging.  This is a 1970 ish motor with a horizontal shaft.
#6 DougT ONLINE
DougT
    Dog Approved
  • 6,568 Thanks
  • 4,741 posts
Posted March 10, 2013 - 07:24 AM
It seems Briggs used 3 different variations. Did you look at the L-head engine manual in the manual section? Wire color and size will help ID what you have and I think that manual explains the difference. Do you know if you have or need a regulator?
#7 KennyP ONLINE
  • 34,220 Thanks
  • 43,339 posts
Posted March 10, 2013 - 07:30 AM
Check out the L-Head Manual, section 7C, page 19 for different wiring diagrams depending on your alternator.
#8 MR Simplicity 6111 OFFLINE
MR Simplicity 6111
  • 14 Thanks
  • 44 posts
Posted March 10, 2013 - 02:29 PM
No, i do not need a regulator as far as i know.
Also tagged with one or more of these keywords: electrics, battery, alternator, wiring
