Bush Hog Rear Forks For Jb Series Tractors
42 replies to this topic
#16 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 21, 2014 - 08:51 AM
Thanks, Scott! I'll see what I can do with that.
#17 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 21, 2014 - 11:40 AM
See what you guys think about this:
Attached File  BH Fork Drawing1.pdf   61.37KB   22 downloads
Scott, one dimension came up different than what you posted. In "Step II", you showed the top of the 3/8" piece as 1-3/4" long. By using your inside dimensions and the thickness, this came out to 2". Not sure if I did something wrong or not. If you can check the drawing against the fork, then we'll know if I need to change something.
Now, how about a few dimensions of the A-frame?  Looks to be a normal size, but what thickness and how big is that angle across the bottom? Hole spacing? Then I'll make a drawing like above with the 3-D view. If you guys want, I can incorporate it all into the original PDF Scott put into the first post here.
Edited by KennyP, January 22, 2014 - 07:17 AM.
New PDF uploaded
  • DH1, Alc, Texas Deere and Horse and 1 other said thanks
#18 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted January 21, 2014 - 01:42 PM
That looks good Kenny, thanks!!
#19 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 21, 2014 - 08:47 PM
Well it seems my two forks have slightly different measurements.......hmmm......can you say "individually hand crafted" and probably because it has picked up something pretty heavy at some point in its life. Here is a picture of the two forks up close to see how they were made. Kenny I came up with a total measurement of 2 7/8 from side the leg to the outside of the 3/8's metal. The open area measurement was 13/16 on one and approx. 7/8 on the other (compared to my original 3/4") So 2 7/8 at the top is probably about right. Your layout looks amazing!! Nice job!!e2y6ega2.jpg
Edited by sacsr, January 21, 2014 - 08:58 PM.
  • Alc, Texas Deere and Horse and KennyP have said thanks
#20 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 21, 2014 - 09:14 PM
I'll get it changed and use the same PDF name, just edit the one above.
  • sacsr said thank you
#21 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 22, 2014 - 07:19 AM
I got the file edited and replaced. All I did was increase the 3/4" dimension to 7/8". This made the 2" dimension to now be 1-7/8". Check it out!
#22 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 22, 2014 - 07:50 AM
Thanks Kenny! I have the measurements for the Aframe and will try to get it up loaded by the end of the day.
#23 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 22, 2014 - 08:35 AM
Thanks, Scott! Gives me something to do on cold days!
#24 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 22, 2014 - 08:51 PM
ImageUploadedByTapatalk1390441735.511485.jpg ImageUploadedByTapatalk1390441753.289502.jpg ImageUploadedByTapatalk1390441784.545748.jpg ImageUploadedByTapatalk1390441796.695277.jpg ImageUploadedByTapatalk1390441805.902106.jpg ImageUploadedByTapatalk1390441817.470153.jpg
Kenny this will give you and idea when you need to translate my hens scratching on the dimensions.
Edited by sacsr, January 22, 2014 - 09:00 PM.
  • DH1 and KennyP have said thanks
#25 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 22, 2014 - 09:07 PM
Thanks, Scott! That does help a lot. I'll make something of all this!
#26 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 30, 2014 - 08:22 AM
I got the drawing finished. I uploaded it here.
  • olcowhand, sacsr and trowel have said thanks
#27 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 30, 2014 - 06:43 PM
Kenny I hope those that down load this info, appreciate the effort you put into it!! Thanks for taking the time and getting it done!
#28 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 30, 2014 - 07:20 PM
If I could find material for the forks, I'd make a set for the FF. Those would be very beneficial.
#29 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 30, 2014 - 09:02 PM
2 ton truck leaf spring.
Edited by trowel, January 30, 2014 - 09:02 PM.
  • olcowhand, Texas Deere and Horse, KennyP and 1 other said thanks
#30 olcowhand OFFLINE
  • 42,400 Thanks
  • 31,803 posts
Posted January 31, 2014 - 08:48 AM
That would work fine!  Acet. torch to heat & bend, and good to go.
  • KennyP and trowel have said thanks
