Help! Need Additional Info Aligning A Plow
13 replies to this topic
#1 Wade M OFFLINE
Wade M
  • 65 Thanks
  • 58 posts
Posted March 09, 2013 - 07:13 PM
I am currently fabricating a sleeve hitch and then going to mount a single plow I found.  I understand to block the left wheels to get the angle. Where do I align the share?  I believe I read in a thread here that the bottom edge should align to the inside edge of the right rear tire. I also think I read that the rear of the blade should be 1" higher than the tip of the blade.
#2 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 09, 2013 - 07:15 PM
You are correct, the outside edge of the plow should be inline with the inside of the tire.
  • JBRamsey said thank you
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 09, 2013 - 07:16 PM
You got me on this one, I don't even know what you are talking about.
Dick
#4 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted March 09, 2013 - 07:24 PM
There is just one thing your doing wrong.Your tip to heel right.Blocking wheels is for setting up 3pt hitch plow not sleeve hitch plow.
#5 MH81 OFFLINE
Posted March 09, 2013 - 07:30 PM
Actually, you do that for setting up a sleeve hitch plow also. With a 3 pt, there are a couple of extra adjustments, but it works well for both.
#6 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted March 09, 2013 - 07:45 PM
I don't follow .You must have different kind of sleeve hitch.My case sleeve hitch or plow ether one has any adjustment you can make blocking wheels.The brinly sleeve hitch plow is already set at angle to run flat when tractor tires are in furrow.
Edited by gopher, March 09, 2013 - 07:57 PM.
#7 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 09, 2013 - 07:55 PM
From what I understand, your sleeve hitch does not adjust the angle, the angle adjustment is on the plow.
#8 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted March 09, 2013 - 08:21 PM
What I'm telling him if he is going to  run a brinly sleeve plow.You do not block up wheels.Brinly is already set at angle no adjustment to make or can be made.This is side to side not the 1 inch landside to point angle.
#9 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 09, 2013 - 08:37 PM
I am not saying that the plow does angle. It was just my two cents on the subject.
#10 MH81 OFFLINE
Posted March 09, 2013 - 08:53 PM
Daniel has done a very good setup article.
http://gardentractor...bottom-plow-r29
#11 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted March 09, 2013 - 09:00 PM
Ditto what Alan said.  Daniel did a great job there.
#12 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted March 10, 2013 - 12:36 AM
Ryan I did not mean to offend you or getting smart with you.When you said adjustment on plow I don't know if you have sleeve plow or any plow.I was just trying to explain how a sleeve plow is made with the 5 to 6 inch angle drop for furrow.My apologies to all on this post.If Wade,s plow is not sleeve hitch style he will have to block tires up to get the hitch bracket at the right angle.
#13 Michiganmobileman OFFLINE
Posted March 10, 2013 - 06:05 AM
There are several manuals (12 at least) for plow installation and setup in the manuals section.  Heres one
http://gardentractor...e-hitch-attach/
Edited by Michiganmobileman, March 10, 2013 - 06:07 AM.
#14 MH81 OFFLINE
Posted March 10, 2013 - 08:59 AM
I had to go do the family thing there and could dedicate the concentration I neede to find the paragraph I was looking for. Sorry.
Anyways, here it is. From the simplicity setup manual
First paragraph under the pic, same for Brinly.
  • gopher said thank you
