Onan Question...
1 reply to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 09, 2013 - 06:09 PM
Do onans normally anyone from the crankcase breather? My 16hp isn't running well and when I pulled the air filter I noticed there was smoke coming from the breather.
Sent from my HTC One VX using Tapatalk 2
#2 boyscout862 ONLINE
  • 13,431 Thanks
  • 9,380 posts
Posted March 09, 2013 - 06:21 PM
Check that the breather is operating correctly. If you are having ring blow by, try adding Marvel Mystery Oil(MMO) to your gas. Run it for a few hours with MMO and see if it gets better. Most times it does. Otherwise you should check your compression. Good Luck Rick
