Ford Lgt 125 Neutral Switch
2 replies to this topic
#1 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted March 09, 2013 - 05:45 PM
I've never been happy with the neutral safety switch on my LGT 125. It's always been a bear to get it into neutral. Usually needed so much force that the shifter went past it. So, I finally took the seat pan off to check it out. There was the remains of a rubber boot on the button for the switch. Which I removed, and I adjusted the switch back a bit. But it turns out that switch needs about the same distance to activate it as the diameter of the shift rod! I'm thinking maybe add a coller to the shaft that would increase the diameter to something like 1/2"?
Someone has been into this before. I could be missing something. Has anyone else had to fix this problem?
#2 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted March 11, 2013 - 07:39 AM
Your 125 is a bit different from my 165. Mine is just a bit off center, but I can find it fairly easily. If it's being a bit hard to get it just right, then you might need to add something to the lever. Even a bit of welding ground smooth might just take care of it. I try to remember to shift mine to neutral before I shut it off.
  • Rock farmer said thank you
#3 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted March 11, 2013 - 06:14 PM
Yea, my LGT 165 is much easier to shift into neutral too. I'm thinking I'll attach a piece of stainless steel sheet metal to the tube frame passing over the switch. A couple of dimples or creases just before and after the switch might work. Trick is to provide a lead-in ramp for the shift rod. I really don't want to just jump the switch.
Thanks!
Joe
