Mid Mount Lift Arm - Allis & Simplicity
allis simplicity hb112
5 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted March 08, 2013 - 06:08 PM
I'm trying to get Ms. Allis ready for summer, but I seem to be missing a part:  the lift arm for the mid mounted implements.  It is item AA in the diagram.  It lifts the mower & grader blade.  The diagram shows that it is bent upwards on the leading edge, where it connects to the tractor.  Unfortunately, I can't fond a photo of that end.  Can some one take some photos or measurements of the lever?  I need to know: length, width, thickness, distance between bolt holes, and the angle of the bend.  Any help would be greatly appreciated.
Mid Mount Bar 1.jpg Mid mount Bar 3.jpg Mid mount Bar 4.jpg Mid mount Bar 5.jpg
Edited by New.Canadian.DB.Owner, March 08, 2013 - 06:09 PM.
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted March 08, 2013 - 06:35 PM
My electric lift removes that part, sorry I can't help.
#3 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 09, 2013 - 10:04 AM
Below are some pics of the lift arm. The first pic shows the lift arm attached to the lift lever on the tractor.
The second pic shows the lift arm in the same position, but removed from the tractor.
The third pic shows the lift arm laying with the inside of the bend facing up. This side should face the tractor frame when mounted. The lift arm is 1 1/4" wide, 1/4" thick and 9 3/8" long. The hole on the left end is centered, top to bottom, and is 5/8" from the end to the center of the hole. The hole on the right end is 11/16" from the end to center and is 7/16" from the bottom to the center. Holes are 25/64" diameter. The bend in the lift arm is 1 3/8" from the right end to the center of the bend.
I don't know the angle of the bend, but when installed, the long, straight end of the lift arm should be about parallel with the tractor frame. See pic below.
Edited by achomesteader, March 09, 2013 - 10:23 AM.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 09, 2013 - 02:37 PM
Awesome!  That is just what I needed!
#5 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 12, 2013 - 11:56 AM
Below are some pics of the lift arm. ...
Lest you think my interest in the measurements was purely academic, here is my rendition of that part.  Still needs a couple of coats of paint & some clear coat, but you get the idea.  Oh, and for those who are trolling the internet looking for the part, it is Simplicity part number is 108198.
MMGBLL mine 1.jpg MMGBLL mine 2.jpg MMGBLL mine 3.jpg MMGBLL mine 4.jpg MMGBLL mine 5.jpg MMGBLL mine 6.jpg MMGBLL mine 7.jpg
  • achomesteader said thank you
#6 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 13, 2013 - 05:21 AM
Also tagged with one or more of these keywords: allis, simplicity, hb112
