Starting My Diesel Education
yanmar diesel
153 replies to this topic
#121 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 27, 2013 - 01:00 PM
What gear did you have it when you were pulling it?  Was the pavement dry?
Dry as a bone Cris.
#122 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 27, 2013 - 01:41 PM
This Video shows the EXACT injectors I have and how I cleaned them
There is also a spring assy in upper section with a drilling for by pass fuel, I cleaned it as well.
I've repaired the throttle linkage and still not confident with it. After a sandwich, I'll pull it off again while battery charges.
Lee
#123 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 27, 2013 - 08:08 PM
I spent nearly 30 years diagnosing manufacturing machinery--from presses to robots and sophisticated motion machinery.. Some 65 ago yrs when I "super-turned" my first bicycle, I had a knack for anything "machinery". In proper analysis an old saying applies. " "If it looks like a duck, quacks like a duck and flies like a duck, its Da#$%^ sure its NOT a chicken hawk." In short, you MUST KNOW how something is SUPPOSED to work properly, if you're going to determine WHY its NOT working properly"
I wanted to learn Diesel and knew the guys here would be great professors. They were !!  But starting this contankerous  @#$%^  was giving us fits and I could detect the "head-scratching" in the posts.
TODAY IS GRADUATION DAY ----Its running and starting like a Swiss Watch.
The last problem?---A clogged muffler. You all know, that if you think the MUFFLER is the problem, you're out of ideas!!!
Standing beside the tractor, instead of ON IT, and cranking--as I have for weeks--I notice a puddle of oil appearing atop the injector pump housing below the muffler, and getting larger. Now the source of this oil was NO chicken Hawk. It appeared to be coming from below the muffler flange. I have NO smoke from the "tailpipe" thru all this, the muffler is clogged perhaps I remove it I blow air thru it and a water hose with disappointing results. Still, I think its NOT a muffler issue.
Still scratching my head , I wander back to the tractor. Standing there a minute or two, I think well, I may as well try to start it.
NO PRE-HEAT, NO COMPRESSION RELEASE, full throttle and I hit the starter. The starter did NOT SPIN 2 Revs and it came to life. Blowing black crap over me, the tractor and then settled down-purred like a kitten at 1000, 1400 and 2000 RPMS like it was supposed to !!!!!
Graduation Day---- :dancingbanana:  :dancingbanana:  :thumbs:  :wave:  :beer:  :worshippy1:  :worshippy1:  :big_hug:  :thank_you:
  • olcowhand, KennyP and twostep have said thanks
#124 HowardsMF155 ONLINE
  • 2,981 Thanks
  • 3,024 posts
Posted March 27, 2013 - 08:15 PM
Congratulations to YOU!!
  • Toolpartzman said thank you
#125 olcowhand ONLINE
  • 43,121 Thanks
  • 31,998 posts
Posted March 27, 2013 - 08:51 PM
That is GREAT news!!!!!!!!!!!!!!!!  Congrats!
#126 OldBuzzard OFFLINE
OldBuzzard
  • 7,107 Thanks
  • 4,820 posts
Posted March 28, 2013 - 12:56 AM
:dancingbanana:  :dancingbanana:  :firejumper:  :rocker2:  :firejumper:  :dancingbanana:  :dancingbanana:  Well done sir!
Now we need a vid of that puppy running  :D :D :D
#127 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted March 28, 2013 - 03:43 AM
Don't know much about diesel's, but never would have thought that was the problem.
#128 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 04:56 AM
It has probably sat in the rain a few times, and the soot settled in the bottom. When I worked for a garage that had a big wrecker, when we towed a big truck for very many miles we would tape the exhaust shut, so that no air would pass through the motr and spin the turbo. If the turbo spins without oil pressure it an damage the bushing in the turbo.
#129 Alc OFFLINE
  • 7,347 Thanks
  • 7,633 posts
Posted March 28, 2013 - 05:38 AM
That's GREAT NEWS !!!!!  I'm not a betting man but I would have bet that a muffler couldn't be so bad to to keep something from starting , learn something new all the time
#130 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 28, 2013 - 05:43 AM
Thankx a lot guys. I know you Diesel guys love 'em, but I have to admit there were a few times that I was beginning to think
you were all NUTS.   :rolling:  :rolling:  I uttered a lot of BLUE language at this tractor and some of it would be Inappropriate for a
bikers picnic !!
If I can figure out how to post a vid I'll be happy to. Its amazingly quiet without the muffler.(And no smoke at all after it starts)     I cut a 4x 6 inch hole in it and all the perforated tubes were nearly clogged and there was a ton of soot in the bottom. Apparently, the more I cranked, the worse it got because after the 1st day I had nothing from the tailpipe.
Everything works---4WD, PTO, 3PT, diff Brakes etc, so this will be a keeper. I had a small, short celebration last night. Theres nothing quite like graduation day.
Edited by Toolpartzman, March 28, 2013 - 05:51 AM.
  • Alc, IamSherwood, KennyP and 2 others have said thanks
#131 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 28, 2013 - 07:11 AM
  Me too Kenny. I was thinking the DUMMY POLICE would be coming up the driveway . :rolling: But, 1)  The verticle pipe had been exposed all this time, and maybe critters built a nest in the pipe.  2) I was out of ideas 3) Everything I had tried had to do with getting fuel/air INTO the compustion chamber, so what about getting SOMETHING OUT? and 4) the 4-bolt flange was easily accessable.
Perhaps there's sufficient blockage that the mix in the chambers was so high, that its was flooding?
All I know is that once the muffler was gone , it started INSTANTLY.
#132 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted March 28, 2013 - 07:27 AM
Any way you can patch the muffler back up after a good cleaning? Or will you just look for a new one?
#133 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,540 posts
Posted March 28, 2013 - 07:38 AM
That is a great feeling... especially after all of the work that was put into it!
#134 olcowhand ONLINE
  • 43,121 Thanks
  • 31,998 posts
Posted March 28, 2013 - 08:11 AM
You've never heard of the "potato up the tail pipe" then!  Shove a raw potato into a tail pipe, and vehicle won't run!
#135 HowardsMF155 ONLINE
  • 2,981 Thanks
  • 3,024 posts
Posted March 28, 2013 - 10:30 AM
Witness Eddie Murphy in "Beverly Hills Cop".
Daniel, you specified "raw" potato.  Do you get a cooked one back?
Also tagged with one or more of these keywords: yanmar diesel
