Starting My Diesel Education
yanmar diesel
153 replies to this topic
#106 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted March 16, 2013 - 11:47 AM
OK from your picture I understand better how the injection works. It doesn't a pump as such, it has individual pumps for each cylinder. If you look close you should see a rod with teeth that rotates a gear on the pumps. It's like a rack and pinion system. When the rod is moved back and forth it rotates the barrels in the pumps. There should be a small camshaft below the pumps that push up on the pumps. There should also be some flyweights to control the speed.
I have seen this before on a 2 cyl Lister Diesel. This is very similar he a Detroit Diesel works except they combine the pump and inj together..
  • Toolpartzman said thank you
#107 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted March 16, 2013 - 12:39 PM
The throttle lever and the foot pedal both push the pump lever to its stop so  something is bent or mis-adjusted. From the looks of your pic, your throttle works opposite of mine, yours pulls back to increase engine RPM. I would say that the spring you see inside the pump is connected to the governor and controls engine speed not returns the lever to idle, the throttle lever should be stiff to move and keep the RPMs at whatever level you set it at.
#108 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted March 16, 2013 - 12:42 PM
Also I forgot to add, the thermal start will actually start a flame in the intake, there is a youtube video of it, I had a hard time believing it also!
#109 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted March 16, 2013 - 12:55 PM
I forgot about the thermal thing, mine had glow plugs.
My little Kubota diesel is being cranked from a 950cc amp Delco battery and it too still struggles at times. I put better cables on it and that made a big difference.
I'd tow it if you have a buddy that can give ya a tug. Put it in hi range and give'r a tug . It will save your battery and starter too. Just don't go too fast!!
#110 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 16, 2013 - 02:20 PM
  'fraid I'll have to Keith. Thats a brand New bbattery and installed new cables also. I guess that means it doesn't lack for compression. Not likely to skid the rears  with those big rice-masher tires.
#111 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 16, 2013 - 02:40 PM
I have it buttoned back up now Pat. I expected just tapped holes in the casting, but somewhat curious why that assembly didn't have some lube. Would that be where pump timing is changed, ?
#112 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 16, 2013 - 02:48 PM
Just learned grandson's in town so gramps needs to make an appearance. As Bill says that throttle linkage needs to be tight and its as loose as a goose. I'd better fix that before the tow. I hope I can get it done before noon tomorrow-leaving on another trip into Kenny's neck -of- the- woods and won't be back 'til thurs.
I guess I could've picked an easier way to get my Diesel education. Can't have better instructors though  :worshippy1:  :worshippy1: Heck,Keith if we get 'er running, I might just make a Puller out of it  :rolling:
#113 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 16, 2013 - 02:49 PM
I'm not sure how its adjusted.
#114 KennyP ONLINE
  • 40,978 Thanks
  • 47,148 posts
Posted March 17, 2013 - 07:35 AM
Where you headed this time, Lee? There's a Farm Show in Claremore the 22nd thru the 24th. NEOGTA will be there.
#115 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 17, 2013 - 08:24 AM
We're doubling-up this week Kenny--2 jobs. Springfield and Lamar, Mo.  My brother was in Tulsa yesterday to depart for 9 days in China with a school group- I instructed him to bring me back something "Made in America". :rolling:
Nothing the 22-24th, I'd like to be there------
#116 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 17, 2013 - 08:46 AM
I will have the DB there and maybe the MF10.
#117 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 27, 2013 - 04:44 AM
After a week of travel and rain:
Tried to pull-start it today. The big rice tires have such a small footprint, that all they do is skid. After "plowing" my gravel driveway and skidding down the street, I'm longing for engines that START WITH ONLY FUEL AND FIRE  :wallbanging:  :wallbanging:
After calming down some I've pulled the injectors and will try to clean 'em tomorrow.
#118 Cvans ONLINE
  • 7,306 Thanks
  • 6,389 posts
Posted March 27, 2013 - 10:04 AM
What gear did you have it when you were pulling it?  Was the pavement dry?
#119 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted March 27, 2013 - 10:43 AM
Was it in the highest gear ? Like hi- 3rd ? It will skidd in lower gears.
#120 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 27, 2013 - 12:59 PM
Yes guys--the highest gear 3-Hi The height of the tire knobs doesn't leave much for ground contact. I plowed 2 very nice furrows in my gravel drive and various black marks in the dry asphalt street--about 3/4 mile all together.
I cleaned the injectors (pintle type)  and filled them with diesel before assembly. Since install, if cranked the battery down now-still no start and am charging the battery again. I cracked the banjo fittings atop the injectors and I'm getting fuel out the return lines.
Also tagged with one or more of these keywords: yanmar diesel
