Have A Belt Problem, 16 H
4 replies to this topic
#1 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted March 05, 2013 - 11:29 PM
Hello;
I am having a tough time with the main gearbox belt coming of much of the time. Belt is the right one and new, good tension , and lined up , checking it with a straight edge. Tough to blow snow when it comes off after 15 minutes of work.
Would appreciate any help as to why this is going on.
  • larryd said thank you
#2 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted March 06, 2013 - 05:44 AM
This is the belt that drives the blower? Are the mounts loose enough that the belt is not staying aligned? Does the belt fit into the pulleys okay?
#3 Lmiller3358 ONLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted March 06, 2013 - 06:45 AM
Maybe missing or needs a belt guide ?
#4 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted March 08, 2013 - 06:39 PM
Hey;
This si the main drive for the tractor, coming from the angled gear box to the 4 speed rear end. Appears that the lower belt guide, and the upper 1/8" "rod" on top are okay. So...any ideas as to why this keeps happening?
Thanks
#5 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted March 08, 2013 - 07:58 PM
Is your frame broken and moving under stress or the transmission is loose and moving sometimes? Maybe the mother mounts are loose?
Joe
