I Think I'm Screwed. Ht-23 Down.
70 replies to this topic
#46 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted March 06, 2013 - 09:32 PM
As it turns out, the fuel pump rebuild kit is not for the K-582 pump. So I just cleaned it up and put it back figuring I'd do it later since I put a shut off valve in the new fuel line.
I looked and could not find a fuel pump rebuild kit for this engine. But I did find new fuel pumps @ 100 or more ?? The K-532 & K-482 are cheaper. What can be the difference ? Arm length maybe ?
I'm pretty sure that I've read that some have done away with the mechanical type pump on the Kohlers. What are my options ? I'll lash a 5 gallon gas can to the hood before I pay 100 bucks for this fuel pump. Lol
It's only a matter of time before I fill this gas tank all the way and forget to shut the inline valve. Then I'll be rite back to a crankcase full of gas.
#47 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted March 06, 2013 - 09:40 PM
Ken i have a few of the rebuild kits for the 582 what is the number you need? that also reminds me to i need to rebuild my pump.
#48 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1231 Thanks
  • 1083 posts
Posted March 06, 2013 - 09:43 PM
Any chance there is an aftermarket pump available? I'm running one on  one of my K series singles and not had any issues so far. I had a link here somewhere for the electric pump you're looking for if I find it I'll be sure and post it.
#49 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted March 06, 2013 - 09:50 PM
The plastic stens pumps wont fit the 582s. The arm bends the wrong way. It cost me $60 to find that out
Edited by rat88, March 07, 2013 - 07:51 AM.
#50 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted March 07, 2013 - 07:46 AM
Sounds like Bob may have what you're looking for. :thumbs:
If you decide to go with the Aftermarket pump, here is one that has come up before in conversations.
http://mr-gasket.com...pump-42gph.html
As for the shutoff, has anyone ever tried these? http://www.dan-marc....9-afc11112.html
  • IamSherwood, blackjackjakexxix, KennyP and 1 other said thanks
#51 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted March 07, 2013 - 08:48 AM
I pmed Bob
That electric shut off is a great idea, can't say I've ever seen anything like that.
Another option.
Edited by NJKen, March 07, 2013 - 08:50 AM.
#52 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted March 07, 2013 - 10:18 AM
Really like the electric shut off, no forgeting to do it,I just tore down a HT-20 that had an impulse pump on it, seemed to be working fine if you can't get the right part
#53 Rock farmer OFFLINE
Rock farmer
  • 1536 Thanks
  • 1432 posts
Posted March 07, 2013 - 10:47 AM
Then and now automotive in Weymouth Massachusetts sells a rebiuld kit for kohler metal body pumps.
They make it themselves. I have never tried it. But that's what I will do if I need one.
Joe
#54 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted March 07, 2013 - 11:06 AM
Joe
Mine is the plastic one, that I just found out from Bob is not rebuildable. Or at least they don't sell a kit to do so.
I'm not sure when it started but it seems that the later years of the K-582 production, they went with a plastic fuel pump. Why ? I guess to save 50 cents in the production cost. Lol
#55 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted March 07, 2013 - 11:28 AM
Saves them 50 cents...costs you $100....big business at it's best. :wallbanging:
I'd go low pressure electric.  No worry about a bad vac pump diaphragm filling the block, plus when the tractor sits a while, the fuel can evaporate from the carb causing much cranking over to build fuel.  With electric, it fills the carb in a matter of a couple seconds.
Here's an example, and Facet makes a low pressure model also.
PUMP
  • IamSherwood, Bud W, WNYTractorTinkerer and 1 other said thanks
#56 pigsitter OFFLINE
pigsitter
  • 1231 Thanks
  • 1083 posts
Posted March 07, 2013 - 10:16 PM
I found the fuel pump link I was looking for http://www.kirkengin...ctronicFuelPump I've ordered from this guy before he's got some neat stuff and I have been well pleased with the service I received!  :thumbs:
Edited by pigsitter, March 07, 2013 - 10:19 PM.
#57 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted March 08, 2013 - 12:27 AM
Thanks Brian, I've bought stuff from him before, can't beat the price on them Kohler twin coils that he sells. I've seen used ones go for more then what he sells new ones for.
#58 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 18297 Thanks
  • 7713 posts
Posted March 08, 2013 - 12:19 PM
Sooo...   Buy another $50 vacuum pump or pony up $30 for a elec pump & shut-off??  I would opt towards the elec!  Are you out using the thing today?  I see it's snowing a lot down your way..
#59 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 08, 2013 - 12:33 PM
Pull the oil stick and check for gas in the oil. I've had an entire cylinder fill to the top with gas from a leaking shut off valve on a zero turn mower. As stated earlier in this thread may be a fuel pump issue.
#60 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 293 Thanks
  • 577 posts
Posted March 08, 2013 - 01:12 PM
Ken I have wanted to change the mecanical pump on my 1886-01 last year and replacements ran in the 200$ range!!! I got mad and installed a mikuni diaphragm  type snowmobile gas pump. The installation called for me to fabricate a little cap to close the original pump hole where I threaded a brake line fitting to hook up the mikuni pump. The pump cost me 0$ as I have a few snomobiles in the barn but they cost around 40$ brand new,  it worked perfectly! I also looked at buying an electric pump but that was too complicated and nearly as costly as the original. I have installed a shut off valve between the pump and the tank for safety.
Edited by hatedge, March 08, 2013 - 01:26 PM.
