Charging Pump On A Sunstrand.
9 replies to this topic
#1 Donnie OFFLINE
Donnie
  • 40 Thanks
  • 37 posts
Posted March 04, 2013 - 10:40 AM
I am new to hydraulic priciples, and have read some great tutorials that have been linked here. I noticed that on a Sunstrand inline hydrostatic  transmission, there is a need for a charging pump due to cavitation. Is this because that the case serves as the resevoir ? Is air entering the line because the case cannot be filled completely ? It seems if I am correct the same components running seperately , with a seperate reservoir have no need for a charge pump.
I should never started studying hydraulics !  Its like a drug !  I find myself mulling over questions all the time now, like a child, why? why ? why ?
Thanks for taking the time to read guys ! :wave:
sorry for the edit, I was wondering if it could be due to the res not being higher than the pump, no flow to the pump.
Edited by Donnie, March 04, 2013 - 10:42 AM.
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 04, 2013 - 11:26 AM
Welcome to GTTalk, if I was you sitution I would find myself the manual that deals with the hydraulics of your make and model of tradtor.
Dick
#3 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted March 04, 2013 - 11:37 AM
The charge pump provides positive pressure for the suction side of the main pump, it kinda works like a 2 stage air compressor.
#4 JDBrian OFFLINE
  • 9,599 Thanks
Posted March 04, 2013 - 11:40 AM
This link may help. http://www.machinery...mission-leakage
  • twostep said thank you
#5 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 9,734 Thanks
  • 5,428 posts
Posted March 04, 2013 - 12:14 PM
Welcome aboard Donnie!!
A Hydro-static tranny isn't a true hydraulic system as the pump has variable output.  A hydraulic pump pumps oil at a speed @ engine RPM and that's it..  The hydro's pump has a movable mechanism or plate that changes the amount of oil pumped and regulates oil flow / tranny speed in that way..  Once you look @ one's inner parts and design you will see what I'm saying..
Enjoy GTtalk!!
#6 olcowhand OFFLINE
  • 38,832 Thanks
  • 30,707 posts
Posted March 04, 2013 - 12:17 PM
And the charge pump also serves for the lift circuit pressure, plus keeps the oil flowing in & around the hydro while it's in neutral position.
#7 New.Canadian.DB.Owner ONLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 04, 2013 - 05:47 PM
... Is this because that the case serves as the resevoir ? ...
I'd have to say no.  The T66 Vickers that was used by Allis & Simplicity have both a charging pump & a reservoir.  The Vickers was replaced by the Sunstrand in later models.
Edited by New.Canadian.DB.Owner, March 04, 2013 - 05:48 PM.
#8 coldone ONLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted March 04, 2013 - 10:10 PM
Another use of the charge pump as it relates to the hydrostatic circuit is as a make up pump. With a hydro static ciruit there are internal losses of fluid due to clearences of the moving parts. The charge pump adds to the ciruit to make up these internal losses. A great place to start with hydros as they relate to GTs is the sundtrand 15 series manual. The 15 and its variants were used in a dozen or more different GTs. Check out the manual section here at GTT to get a copy.
  • ol' stonebreaker said thank you
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted March 04, 2013 - 10:43 PM
   That is the primary purpose of the charge pump. The hydro trans circuit must have a positve pressure in order to function.
        Mike
#10 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted March 05, 2013 - 06:34 AM
Enjoy GTtalk!!
There are variable displacment hydraulic pumps that increase or decrease flow by using pressure to adjust the swash plate. They work kinda like a pnuematic back pressure regulator.
A hydrostat is just the manual version of this.
