Bolens 900 Engine Swap
Started by
Nascar3244888
, Sep 27, 2010 04:12 PM
24 replies to this topic
#16
OFFLINE
Posted October 04, 2010 - 02:40 PM
i ended up going with the coil, and it runs!!!and drives!!!! It will be in my next vid!!!!!
#17
ONLINE
Posted October 04, 2010 - 05:29 PM
Thats GREAT!!!!
Cant wait to see the video!
#18
OFFLINE
Posted October 09, 2010 - 08:28 PM
hey guys ive been having little crappy issues with the internet lately they seem to be fixed now so look for the running and driving vid of the 900 tomorrow i will try and upload it tonight
#19
ONLINE
Posted October 09, 2010 - 08:29 PM
Hope your internet gets better for you.
Looking forward to seeing the video
#20
ONLINE
Posted October 10, 2010 - 08:41 AM
Nice !!
you mentioned in your video that you kept the TRA's pulley on?? How did you do that? Did you swap the clutch and drive shaft over?
#21
OFFLINE
Posted October 10, 2010 - 06:11 PM
lol, no it was actually becuase i couldnt get the s8d one off. I measured where the belts went up to the engine somehow or another and was able to make a slight adjustment to where the pulley was on the crank and it lined up perfectly, but there is a setback though, I can only use the high range belt on it. The pto belt lines up and is the same. I have to make a vid of it to explain it better but it works well as shown in the vid. I might have to buy a s8d pulley and put it on, but for now it will do. I would really like to get the correct carb for the tra but i did find one im just hoping it works because the carb on it now is more suited for the s8d good for now though, i may be able to repair the broken one to i havent looked into it yet.
#22
ONLINE
Posted October 10, 2010 - 06:23 PM
Do you have a puller to get the pulley off?
If you don't, they are usually pretty cheap and probably would be less expensive if you were to buy another pulley.
Once again congrats on getting it running.
Now my 900 is down for repairs:wallbanging: LOL
#23
OFFLINE
Posted October 11, 2010 - 04:21 AM
i was having problems with the set screws, they are either stripped or something
#24
OFFLINE
Posted October 20, 2010 - 04:20 AM
just wanted to give you an update...I got the throttle cable working, and it seems to work ok. I can only rev it up though if i put it on 1/2 to 3/4 choke. I am making a vid of it so you guys can see what im talking about. I have adjusted the screws every which way but it doesnt want to rev up without choke on, on the other hand it idles no problem with no choke.
#25
OFFLINE
Posted October 20, 2010 - 04:28 AM
Waiting patiently for the video.
