Can A Threaded Crank Be Adapted To Gt Use?
19 replies to this topic
#16 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted March 06, 2013 - 10:46 PM
I have used a taper lock on a tiller engine that did not have a keyway. NO PROBLEM!
  • motobreeder said thank you
#17 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted March 10, 2013 - 06:50 PM
Picked up the motor.
1.25" threaded crank shaft:
What is this weird oil tank?
And something that looks a bit like a regulator?
Edited by motobreeder, March 10, 2013 - 06:50 PM.
#18 olcowhand ONLINE
  • 41,222 Thanks
  • 31,437 posts
Posted March 10, 2013 - 07:08 PM
That is a remote reservoir for motor oil.  It keeps the correct level of engine oil as it runs.  I'm sure the regulator looking thingy controls the level of the oil, and may need to be placed at the right height to work.  You can change out the oil pan to a normal one with an oil fill tube.
#19 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted March 10, 2013 - 07:15 PM
Could that thing be a check valve?
Lets oil into the crankcase but non goes out to the tank.???
#20 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted March 23, 2013 - 10:45 PM
Tried starting the motor last weekend.  It would idle OK, but revved up it was more productive than a smoke grenade.  A couple minutes and was at near zero visibility in the garage.  Stepped outside to get some air - as I emerged from the smoke, my son said it looked like something from a horror movie.
Got some time today to try some trouble shooting.  Pulled the air breather - the filter is soaked with oil.  That caused the intake to suck oil from the crank case.
Removed the air filter and tried again.  A few puffs of smoke from the oil in the intake and then it was as clean as anything.
Revving it up, would sputter and stall - a bit of choke would help it recover.  Hopefully all it needs is normal maintenance (carb kit, and cleanup of the fuel system).
For now, it's going to sit on the side and wait for the right tractor.
In the mean time, I'm going to keep an eye out for brackets to hold a starter/generator.
