Zenith Carb Adjustment Help
6 replies to this topic
#1 Chucknbob OFFLINE
Chucknbob
  • 90 Thanks
  • 72 posts
Posted March 02, 2013 - 07:16 AM
So I've got a 1254 with a 12 horse wisconsion and a zenith carb. I had to rebuild the carb, and I'm having a couple problems getting it adjusted. I set it to where the book says to set the 2 to jets as a starting point, but here's my issue:
No matter where I have the choke and throttle set, it won't start unless I give it a shot of ether. Once I give it a quick blast, I turn off the choke, and it runs great. I can rev, idle, whatever I want to do. What adjustment do I make to help starting?
#2 boyscout862 OFFLINE
  • 15273 Thanks
  • 10026 posts
Posted March 02, 2013 - 07:55 AM
Is the choke actually closing? The linkage may need adjustment.
  • HDWildBill said thank you
#3 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted March 02, 2013 - 08:57 AM
When you rebuilt the carburetor did you pull the welch plugs and clean behind them?
#4 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted March 02, 2013 - 09:07 AM
Is that a cast iron or aluminum Zenith?  Post your carburetor number so I can see what you have.
Somethings wrong with your choking system.  When the linkage is pulled out completely, does the choke plate seal in the carburetor?  It sounds like your Wisconsin is cold-natured, and it needs a drink of fuel to start.  If your choke plate doesn't seal 100% the engine will have trouble siphoning out enough gas to start.
Zeniths also don't siphon well if there are air leaks in the system.  I'm assuming you repacked the throttle shaft.  Do you have good gaskets on the intake manifold?
You can also try enriching the fuel mixture slightly.  Be careful, since it sounds like it runs well once it gets going.
Ben W.
  • HDWildBill and boyscout862 have said thanks
#5 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 18350 Thanks
  • 7721 posts
Posted March 02, 2013 - 09:25 AM
Choke problem , Air leak or vacuum problem could the cause..  Are you sure the float is set correctly?  If the fuel bowl level is too low this could affect the fuel draw @ start up..  Just a few thoughts..
  • bhts, HDWildBill, boyscout862 and 1 other said thanks
#6 Chucknbob OFFLINE
Chucknbob
  • 90 Thanks
  • 72 posts
Posted March 02, 2013 - 10:50 AM
I know it's not a linkage issue, I disconnected the cable and moved it by hand at the carb. I have to shut the choke as soon as it starts or it dies. It does sputter for the first minute or so until it warms up, I just chalked that up to the engine being cold natured and the cold air.
No, I didn't pull the welch plugs. I soaked it for a couple days in Berryman carb dip and used cans of carb cleaner afterwards.
#7 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 18350 Thanks
  • 7721 posts
Posted March 02, 2013 - 11:45 AM
A plugged idle jet or passage will make things like this happen..  A small wire or torch tip cleaner helps determine the passages are clear
  • superaben said thank you
