Confused About A Lift Rod Setup
hb112
7 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted March 01, 2013 - 06:58 PM
In keeping with my 3 hours of maintenance for every hour of seat time, I pulled Ms. Allis back into the barn today to fix the snow plow lift rod.  The top end was worn & needed to be beefed up with some welding.
Anyway, when I went to put it back together, I followed the pattern used by the PO: stop block, spring, washer, pin, connector, stop block.  But then I thought, "Why is the spring behind the pin?"  So, I moved it ahead of the connector.  But now I'm wondering "Why is it in front of the stop block?"   More to the point, "Why is the pin in the pattern at all?"  The manual shows only a bar shaped like a Z.  (Both holes were there when I disassembled it.)
Any ideas?  Anyone have a picture of the proper setup or bar?
Edited by New.Canadian.DB.Owner, March 01, 2013 - 07:02 PM.
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 01, 2013 - 07:21 PM
I don't have one of these but. I am thinking it is for a float or no float type of position?
If you put the pin back to the way it was, it seems like it would bypass the spring and allow the blade to have more positive down pressure.
If you remove the pin it looks like it would allow the blade to come up if you hit something solid?
The pin in the after picture position looks like it will make no difference.
Also the shaft collar up stream on your rod looks like you could set that for the amount of tension you want on the spring (does that move?). For either more pressure on the plow or less
  • Michiganmobileman and New.Canadian.DB.Owner have said thanks
#3 Michiganmobileman OFFLINE
Posted March 01, 2013 - 07:36 PM
Chris pretty much nailed it, same rod on my blower and blade.
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 01, 2013 - 07:39 PM
Yep, it has some give before it starts to bend, since it is not a 'trip' plow.
#5 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 01, 2013 - 07:46 PM
Yes, the up steam collar should be movable, if the screw isn't rusted.  Your down-force argument makes sense.  Hadn't thought of that.  I may remove the pin but keep it handy for those moments when more down-force is required.
  • chris m said thank you
#6 glgrumpy OFFLINE
  • 8,606 Thanks
  • 7,913 posts
Posted March 02, 2013 - 04:40 AM
I agree with moving the collor down to what you think is good tension and pull that pin in front. This is kinda like  a Power King lift link on there 3pt or lift hitches, but they used a much shorter spring and it has several holes in the rod to adjust the tension with washer and pin,but also had movable block for major adjustments.
#7 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 02, 2013 - 09:33 AM
The hitch and lift rod, that you now have on your snow plow/dozer blade, were not in use when your tractor was built. The hitch, from your tractors era, had the lift arm sloping back toward the tractor instead of being straight up. Also, the lift rod was just a solid rod with 90 degree bends on both ends.
The pin, that you are having trouble finding the correct place for, does not belong on that lift rod at all. Below are links to manuals showing the set-up like you now have. They explain the assembly and adjustment of the lift rod and components.
http://bsintek.basco...vh5kbp796Dq.pdf
Disregard page 4 of the second manual. It shows the hitch and lift rod for the small frame tractors.
Edited by achomesteader, March 02, 2013 - 09:35 AM.
  • chris m and New.Canadian.DB.Owner have said thanks
#8 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 02, 2013 - 12:43 PM
Thank you greatly, achomesteader.  That pretty much explains my tractor.  It seems to have been cobbled together from a couple of different models over the years.  It may not be "all original", but I enjoy it.  Again, thanks for setting me straight on how that lift assembly goes together.
Also tagged with one or more of these keywords: hb112
