Is It Worth It?
5 replies to this topic
#1 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted February 28, 2013 - 07:44 PM
I have an old Gilson sitting out back I was given last year. I put it outside because it doesn't look like a real rugged tractor or something that can be used for heavy work and it needs alot of work. I was looking for advice about the quality of the tractor and if it is worth sinking money into or if I would be better off leaving it outside. the motor does spin but needs a new flywheel. what would this tractor be worth if I got it looking good and working well? is it a rare tractor? below are pics. of it.
Edited by Matt O, February 28, 2013 - 07:44 PM.
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 28, 2013 - 07:55 PM
That's a tricky question. Even though it doesn't look real rugged it is better than today's LT's. But even if you do fix it up it probably won't be worth all that much. I would take the tiller of it, adapt it to something else and see if anybody needs parts off the tractor. The wheel weights look like they are for 12" wheels instead of the 10"?? on that one. Good luck whatever you decide to do. :thumbs:
#3 boyscout862 ONLINE
  • 13,246 Thanks
  • 9,299 posts
Posted February 28, 2013 - 08:44 PM
Welcome to GTT. Leave it out but cover it. Keep you eye out for a parts engine to cannabilize. Gilson was a decent tractor. That tiller attachment is worth abit. I'd look for a parts machine. Then try to fix it with the best parts. That way you only invest time. I've gotten most of my parts machines for free by removing them from peoples yards(with permission). There is a Gilson Hood laying on the side of a yard near me. I fix up and sell LTs. They sometimes attract GTs as tradeins. Good Luck, Rick
Edited by boyscout862, February 28, 2013 - 08:46 PM.
#4 tractorgarden OFFLINE
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 28, 2013 - 08:55 PM
Your tractor is the same as a ford yt-18 series. hope this helps.
#5 superaben OFFLINE
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 01, 2013 - 08:18 AM
What engine is in it?
Ben W.
#6 Guest_rat88_*
  • Guests
Posted March 01, 2013 - 01:25 PM
A flywheel for a Briggs twin should be easy to find. Check local mower shops. I get some good parts real cheap in the fall when everything slows down. They scrap out The DOAs and usually sell at scrap prices. Shipping may be more than the flywheel, so buy local if you can. I think I have 3 on parts engines in the chicken shack
