Panzer Rear End Work
9 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 28, 2013 - 08:48 AM
im working on my 1107 this week, Im pulling the who seat and fenders off so i can get to the rear end to do some work on it.  It started to leak some so its getting pulled apart and gone over. im going to paint the gears that the chain runs on black because they are rusting.  im goin to also check wat my gear ratio is in the rear end. wish me luck
#2 Alc OFFLINE
  • 7,129 Thanks
  • 7,532 posts
Posted February 28, 2013 - 08:56 AM
Good luck with your rear !  Isn't that a Mopar rear in them ?  Wonder if a possi was made for that model rear ?
#3 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted February 28, 2013 - 09:28 AM
I saw somewhere in my various Panzer pdf files that they specified pre '57 or '58 rear ends but I don't know if they used anything newer on the later build tractors like the 1107 Panzers and Meteors.  Mine has the tapered, keyed axles so the rear has to be pre '65.  I believe Mopar's Sure-Grip limited slip was first available in '58.
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 28, 2013 - 12:27 PM
not sure what year rear is in this tractor. im goin to pull it apart tomorrow.
#5 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted February 28, 2013 - 02:48 PM
Please take some photos to document the adventure. Curious what the inside looks like.. but not really enough to pull it apart. LOL
#6 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 07, 2013 - 08:31 AM
got the seat and covers off. rear end looks rough on the outside. a lot more rust and oil leaking then I originally thought.  will get pics later.
#7 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted March 13, 2013 - 08:07 PM
Well, what's the plan, stan?
Any idea where it was leaking from?  Sounds like it's around the pumpkin and not the axle ends, right?
#8 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 14, 2013 - 07:42 AM
the pumkins leaking. I got it down to the pumkin so far goin to pull apart tonight and redue the gaskets
#9 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted March 22, 2013 - 08:12 PM
On the front of the pumpkin around the bolts?  Were any of the bolts loose?
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 25, 2013 - 09:23 AM
no when i loosened them gasket pieces fell out. gota pull the axles out to get the pumkin apart.
