Ready To Give Up, Jd 314 Eta: Not Yet !
50 replies to this topic
#1 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 07:17 PM
This thing is driving me nuts! After i replaced the starter , starter cylinoid, put on used carb, redid the wiring, two gas tanks( one had a busted petcock), new battery, new cables, new fuel lines, new hydro vent hose, it still won't fire!!! I found out tonight the coil might be bad( if i tested it right). The fuel pump wasn't pumping, so i took it apart to find a crapload of rust particles jammed in there. I got that all cleaned out and put it back , still nothing! I about ready to take it out back and shoot the damn thing!! Wife doesn't understand how much work and money i put in this thing already. Am i being a crybaby, and should suck it up? :D
Edited by nade-em, February 28, 2013 - 07:36 PM.
  • boyscout862, twostep and larryd have said thanks
#2 MH81 OFFLINE
Posted February 27, 2013 - 07:37 PM
Do you have spark at all? I am unfamiliar with the 314, but I assume it also has the Onan like the 318?
  • larryd said thank you
#3 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 07:39 PM
No spark at all. I checked the coil with the key on, and its showing 12 volts on the + post. All the safety switches are working.( seat, PTO, and nuetral )
ETA: Has the Kohler 14 HP, single cylinder
ETA 2 : Bob from Bob's Lawn and Garden tractors loves me! I think he is planning on a new boat because of me :D . Just kidding , Bob's a really nice guy and has given me good deals. :thumbs:
Edited by nade-em, February 27, 2013 - 07:42 PM.
#4 MH81 OFFLINE
Posted February 27, 2013 - 07:40 PM
Does this engine have the pickup or the points?
#5 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 07:44 PM
It has breaker points, on the drivers side. They look good, gap is good, and not corroded.
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 27, 2013 - 07:56 PM
How did you test the coil?
Have you replaced the condensor?
http://gardentractor...=+testing +coil
  • larryd and nade-em have said thanks
#7 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 08:01 PM
Yep, tested it just like this. Got nothing. Haven't replaced anything, it was too late. Bob was closed by then. I really don't want to buy a new coil. Rather have used because of prices.
#8 MH81 OFFLINE
Posted February 27, 2013 - 08:06 PM
Do you have a continuity checker?  If the coil is good, you may be dealing with a ground or adjustment issue at the points.
#9 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted February 27, 2013 - 08:12 PM
did you check the wire from the coil to the points?
I had about the same problem - no spark
I checks the voltage from the coil to point and it was less than 3 volts
make  a test wire from the coil to the points and now it has spark.
used my spark plug test and I can open it up to a 1/2" and it still has a good spark
replace that wire and it runs better than it has it years
#10 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 08:14 PM
Will an old analog Triplett  multi meter work? What setting should i use?
#11 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 08:15 PM
No, but i will try that tomorrow. Thanks!!
#12 MH81 OFFLINE
Posted February 27, 2013 - 08:19 PM
First Step:
With battery disconnected and key on, all safety switches in "start" positions:  put the ohms setting and test from coil - to ground.  turn the engine over by hand.  when the points close, you should get very low resistance and with them open, infinity.
  • sacsr, larryd and nade-em have said thanks
#13 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted February 27, 2013 - 08:20 PM
Sounds like you got the starter problem fixed.If you have time tomorrow bring the coil by and i will test it for you.
Edited by bhts, February 27, 2013 - 08:24 PM.
  • MH81, Texas Deere and Horse, sacsr and 2 others have said thanks
#14 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 27, 2013 - 08:31 PM
Yep, the starter cranks over like a champ. Thanks for the help with that too. :thumbs:
#15 Trav1s ONLINE
Trav1s
  • 3,166 Thanks
  • 4,282 posts
Posted February 27, 2013 - 11:00 PM
Let us know what happens with the coil.  I had a bad coil that would stop working when it was hot.  Let the machine cool and it would run until it got hot.  If I recall correctly a coil with an internal resistor from my local Napa was less than $20.
