Project Briggs 8s
20 replies to this topic
#16 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted March 02, 2013 - 08:06 PM
 I got a little ways down the road on the 8s today. I honed the cylinder, installed the new rings, and assembled the long block. I had to use the thickest mag plate gasket in the set (.015) to achieve proper end play clearance. The gasket set comes with a .005, .009, and .015 mag plate gaskets. My end play ended up at .003, which is great. The tolerances are .002-.008. Although, I always check my clearances, I don't usually talk about it here, but I figured since I'm installing parts that were'nt meant to be on this engine, I would mention it. This little engine has fantastic compression, especially since its not even broke in yet. I also cleaned the carburetor, and the gas tank. I intend to get this engine running, and work all the bugs out before I paint it. Once its running perfect, I'll break it back down, and paint it. Here are a few pics. :thumbs:
Matt
#17 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted March 02, 2013 - 08:14 PM
 Here are a few pics of the carb, and tank.
Matt
#18 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted March 03, 2013 - 06:05 PM
 Project 8s Lives! It runs great. This litttle engine started on the second pull, after putting it together, and other than a little carb adjustment, I haven't had to do anything to it. Its time to disassemble, and paint it. :thumbs:
Matt
  • superaben said thank you
#19 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 03, 2013 - 08:46 PM
Matt
I am impressed, Matt.  I'll bet you you were glad to hear that critter run!
Did you send the link to Will?
Ben W.
  • bowtiebutler956 said thank you
#20 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted March 03, 2013 - 08:53 PM
Ben W.
Yes, I was very pleased to hear it run so well!  Yes, I did send the link to Will, but I haven't got a responce yet. :thumbs:
Matt
#21 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 05, 2013 - 08:01 AM
Matt
 I would love to hear what he says.  He's probably digging through all of his engine books trying to make sure there wasn't such a thing as an 8S!
Ben W.
