Toro Roller Shaft Size Model 59004
6 replies to this topic
#1 Old Suburban Tractor OFFLINE
  • 5 Thanks
  • 9 posts
Posted February 26, 2013 - 08:10 PM
Does anyone know the shaft roller O.D. on a Model 59004 42" Deck, I believe that it's either 1/2" or 5/8". I'm trying to find some replacement rollers for one on the rear and two on the front. The current rollers are worn, the deck shaft holes are worn. The rollers I.D. from what I can tell is 2-1/2".
This same mowing deck was carried over from the 1966 large frame Springfield tractors and continued to be used
from 1967-1971 on these Toro models -
#55300 1967 Suburban 12, #55400 1967 Suburban 12, #55301 1968 Suburban 12,
#55401 1968 Suburban 12, #55302 1969, 1970 & 1971 950 Suburban, #55402 1969, 1970 & 1971 960 Suburban.
#2 boyscout862 OFFLINE
  • 13,428 Thanks
  • 9,379 posts
Posted February 26, 2013 - 11:12 PM
Welcome to GTT. Someone that knows this will be along to help you soon. Meanwhile enjoy the rest of the site. Rick
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted February 26, 2013 - 11:47 PM
I have several decks, so I can tell you later this week the correct dimensions.
  • 14,862 Thanks
  • 15,511 posts
Posted February 27, 2013 - 12:17 AM
Thanks Casey, I knew you would be the one that could help him out. :thumbs:
#5 Old Suburban Tractor OFFLINE
  • 5 Thanks
  • 9 posts
Posted February 27, 2013 - 05:05 AM
I noticed a typo (on the rollers I.D. from what I can tell is 2-1/2"). I mean't O.D not I.D. Thanks for the help.
#6 Old Suburban Tractor OFFLINE
  • 5 Thanks
  • 9 posts
Posted March 01, 2013 - 04:02 PM
Also need the dimesions & a pic of the Blade Brake Rod 70631, if possible. Having my fabricator/blacksmith making one of the Lift Links 7-0608 & Bell Crank 7-0265 & if I had the dimesions/pic of the Blade Brake Rod 70631 it would be easier for him. The spring, nut and washer should be no problem for the Brake Rod.
Thanks
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 01, 2013 - 08:05 PM
I will see what I can do...
