Snapper 38" snowblower made to 48"
39 replies to this topic
#16 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted October 05, 2010 - 07:03 AM
Looks good! I wish I had those fabrication skills and the equipment to do it.
#17 mjodrey OFFLINE
Posted October 05, 2010 - 07:05 AM
Wow,that looks great.
#18 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted October 05, 2010 - 07:23 AM
Nice job. I am impressed.
#19 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted October 08, 2010 - 07:56 PM
I made the drive system for the snowblower to beable to run the blower off the MF 1655's front PTO. I welded a stub shaft onto a removable plate that I bolted in place right in front of the blowers main drive pulley and shaft.I then had to add another pulley 1" away from the original pulley.I added in some idler tensioner pulleys and springs completing the drive system.I'll still have to put the slip yoke and u-joints onto the yoke thats on the drive pulley. The way its set up is like this 2500 rpm from the pto running a 4.5" pulley driving another 4" pulley=2813 rpm that 4" pulley is driving another pulley thats mated to it.It's a 3" pulley driving a 8" pulley on the snowblowers shaft so its turning that shaft at 1055 rpm.I used some of the pulleys that were already on the blower and had to add in the one with the pto yoke as well as the 4" one in order to get as close to 1000 rpm as I could.So thats what the impeller is spinning at.It's going to throw snow really well.:madhop:Larry
#20 MH81 OFFLINE
Posted October 09, 2010 - 12:39 PM
With all those pulleys, I'd get confused, get the rotation wrong & make a "Snow Sucker". Nice fab work. Hope it blows the snow to the neighbors house.:D
#21 caseguy OFFLINE
  • 1,629 Thanks
Posted October 09, 2010 - 03:21 PM
That should about be ready to throw some snow around! Lets not be in too much of a hurry to test it out though. I'm definitely NOT ready for the white stuff yet! You do some great fab work! Sheet metal is tricky to work with, but it looks like you've got it down!
#22 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted October 09, 2010 - 07:02 PM
I cut out the mounts for the snowblower using my cut off saw out of 1/4" plate and once I had the proper shape ground into the end,I was ready to weld them onto the blower. I put the frame that I had from the other blower onto the tractor and lined up the blower to that frame I had to make sure it was a certain distance from the tractor so that I could use the pto shaft etc: that I have.I also made sure that it sat square with the tractor as well.I then clamped everything together and did a few quick spot welds here and there.I then removed it all from the tractor and then welded it all together. Once it was done I remounted it to the tractor and tried it out.I had to do a bit of tweeking with the lift mechanism to get it to raise and lower properly.I still have a bit more to do before it'll be ready for paint,[It's getting pretty close for that. Larry
#23 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted October 13, 2010 - 08:25 PM
I made the belt guard out of the metal off a old washing machine.I first used cardboard to make a pattern from then cut the the metal with tin snips.Once I had the metal cut I welded it together with my welder set on DC set at 70 using 6011 rods.Once it was welded I painted the belt guard black and then painted the snowblower red.Once it was done I mounted it onto the MF 1655 and took some pics of the unit.I picked up the electric window motor today so tommoro I'll mount it onto the blower to use it for a electric chute turner. Larry
#24 Bolens 1000 ONLINE
  • 15,288 Thanks
  • 18,233 posts
Posted October 14, 2010 - 07:44 AM
You should be all set for snow now :thumbs:
#25 limebuzz ONLINE
limebuzz
  • 1,055 Thanks
  • 1,005 posts
Posted October 14, 2010 - 12:19 PM
Looks very good.If you didn't tell us, we wouldn't know it was not factory!
#26 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted October 14, 2010 - 01:23 PM
I made up a cardboard template to cut out the 1/8" plate of steel that I used to mount the power window motor onto to use as the chute rotator.I painted it up and once it was dry I installed it .I wired the chute turner to the tractor and now the tractor and blower are ready to go.I'll load the tires before I need to use it as well as install the chains and the winter cab.Larry
#27 caseguy OFFLINE
  • 1,629 Thanks
Posted October 14, 2010 - 04:49 PM
That thing looks phenomenal!! I can't believe you do all that with that concrete saw! That is excellent work! Great looking machine Larry! Lets still not get in too much of a hurry to test it out though LOL.
#28 DH1 ONLINE
DH1
    Electric Tractors
  • 5,365 Thanks
  • 5,605 posts
Posted October 14, 2010 - 08:30 PM
Good stuff, I'll say 1 thing you certainly know how to finish what you start, looks like it was made that way from the factory.
#29 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted October 23, 2010 - 06:32 AM
Congrats on a job very well done Larry! You do first class work. That should really clean up the snow fast for you.
#30 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted October 23, 2010 - 07:37 AM
Thanks for all the replies and kind words.Larry
