Ford Mower Deck Help
ford mower deck
25 replies to this topic
#1 rod0717 OFFLINE
rod0717
  • 2 Thanks
  • 11 posts
Posted February 26, 2013 - 12:51 PM
Recently got a lgt 145 in peices, I think it's a 73 or 74, No mower deck came with the tractor, so I am trying to adapt a deck to it. I need some good close up pic's of the front and rear mounting brackets
that are on ford mower decks, not sure how the front latch works? If you could hold a tape measure up
to them so I know have an idea of the demenions that would be great. Also how deep are the slots on the rear hooks.
thanks Rod
#2 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted February 26, 2013 - 07:48 PM
Haven't got any dims for you because the deck is out in the snow. But, here's some pictures;
Edited by Rock farmer, February 26, 2013 - 07:51 PM.
#3 KennyP ONLINE
  • 40,866 Thanks
  • 47,089 posts
Posted February 27, 2013 - 07:23 AM
My deck is also unavailable for measurements. Maybe one of the other Ford guys can chime in with some help!
  • Old Door said thank you
#4 poncho62 OFFLINE
poncho62
  • 2,110 Thanks
  • 1,779 posts
Posted February 27, 2013 - 09:23 AM
Mine are under 2 feet of snow too.....but do you have the framework that goes under your tractor between the deck and the tractor?....You will need that.
#5 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted February 27, 2013 - 12:13 PM
Mine were 4' under the snow, but I dug them out to start rebuilding them, I will try to get a pic with measurements for you
#6 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted February 27, 2013 - 02:20 PM
I have a jac mower deck 42in for sale.It is in great shape.
#7 Arti OFFLINE
Arti
  • 1,371 Thanks
  • 995 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted February 28, 2013 - 08:15 AM
This is a deck that is for a Closed side LGT 165. I assume that is the same ??
  • KennyP and rod0717 have said thanks
#8 KennyP ONLINE
  • 40,866 Thanks
  • 47,089 posts
Posted February 28, 2013 - 08:24 AM
I believe they are the same, only minor part changes. I am working on a parts list to add into the operators manual for the 42"& 50" decks right now. This will cover the 09JC9789, 9788, 9826, 9828, 9835, & 9838 decks.
  • rod0717 said thank you
#9 rod0717 OFFLINE
rod0717
  • 2 Thanks
  • 11 posts
Posted February 28, 2013 - 10:56 AM
Thanks for the pic's, if any one else has pic's post them too, the more the better.
? so when you attach the front latch to the carrage bar , does the latch swing up and then snap back down into place?
Please advise..
thanks Rod
#10 Arti OFFLINE
Arti
  • 1,371 Thanks
  • 995 posts
Posted February 28, 2013 - 11:52 AM
Please advise..
thanks Rod
You open the latch manually it sort of goes over center and stays open, With the mower in place just pop it down and the spring holds it.
#11 KennyP ONLINE
  • 40,866 Thanks
  • 47,089 posts
Posted February 28, 2013 - 05:14 PM
Here's a copy of the Operators manual for the 42" & 50". This is the one I am adding the parts list into. Then I will put it into the manuals section.
Attached File  Fordmowers.pdf   1.17MB   205 downloads
#12 KennyP ONLINE
  • 40,866 Thanks
  • 47,089 posts
Posted March 01, 2013 - 06:12 PM
File is finished and uploaded.
#13 nagrof OFFLINE
nagrof
  • 3 Thanks
  • 4 posts
Posted April 06, 2013 - 10:48 AM
Attached File  ford brackets1.pdf   558.49KB   76 downloadslgt deck 3.jpg lgt deck 4.jpg lgt deck 5.jpg lgtdeck 2.jpg lgt deck1.jpg I took some pics last night  that may help you,I may wind up doing the same if I can't find spindles I need. I also cut out some cardboard cut outs of brackets,in case I need to cut some new ones. Its pdf if I can figure it out I will post it also. Brackets are 1/4 steel, 10" apart from outside measurement,front and back brackets.
This is off a LGT 125 42" mower deck.
The 26.25 measurement is my attempt to measure inside brackets curve on back to inside curve on the front,probably more accurate to measure on tractor bracket.
* the pdf of front bracket only basically shows the front,the bracket continues on where it is welded to the top of deck.
I figured different deck the back of the bracket would need to be different anyway.
the little one is the front bracket inside piece,that flips back to attach deck ,you need two on 3/8 rod.
Edited by nagrof, April 06, 2013 - 12:17 PM.
#14 rod0717 OFFLINE
rod0717
  • 2 Thanks
  • 11 posts
Posted May 29, 2013 - 11:04 AM
Thanks Nagrof..Good pic's, The pdf file is great I should be able to make them now.
Thanks again Rod
#15 Old Door OFFLINE
Old Door
  • 2 Thanks
  • 13 posts
Posted June 17, 2013 - 06:33 PM
Thankyou KennyP I am new to this forum and have a Ford LT100 with a 42 inch deck.The manual for the 09JC9835 dec k is great but I can not figure out how to drop the deck.I also cannot upload parts list as I need to get main drive belt and belt for outside blades..                            Thankyou again for a great site.
