Cub Cadet 124 front PTO removal
3 replies to this topic
#1 timdaugherty23 OFFLINE
timdaugherty23
  • 5 posts
Posted September 26, 2010 - 04:49 PM
I own an old 1967 Cub Cadet 124 and i was wondering how to remove the old front PTO pulley off the engine pulley. The PTO pulley spins for a few seconds after you shut off the engine because the bearing is shot, and it's annoying because it squeaks to a stop. How can i remove it? Thanks y'all.:confuse:
#2 Bolens 1000 OFFLINE
  • 15,298 Thanks
  • 18,236 posts
Posted September 26, 2010 - 05:01 PM
Welcome to the Forum! :wave:
I dont know anything about the Cub cadets so I'll leave this for a Cub guy to answer.
#3 mjodrey OFFLINE
Posted September 26, 2010 - 05:03 PM
timdaughterty23:welcometogttalk:glad to have you here.
#4 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted September 26, 2010 - 05:19 PM
Just behind the pto pulley groove, around the perimeter there are 3 holes. Clean them out good, then remove 2 set screws from each hole. The top one is just to lock the bottom one from moving. Once all 6 are out, then you can pull the pulley off the bad bearing.
