Military standard engine help
7 replies to this topic
#1 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted September 26, 2010 - 04:45 PM
I got a Military engine M#2A016-111. Iam not geting spark.Dose anyone know about them Thanks Jake
#2 mjodrey OFFLINE
Posted September 26, 2010 - 05:01 PM
Jake :welcometogttalk:glad to have you here.
#3 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted September 26, 2010 - 05:42 PM
Thanks for the welcome
#4 olcowhand ONLINE
  • 40,383 Thanks
  • 31,180 posts
Posted September 26, 2010 - 07:27 PM
I have a manual in pdf for the 4A0-32, which is nothing more but double the engine being a 4 cylinder. I just uploaded to the manual section. Look under "Engine Manuals". It will be near bottom of page.
I have a 2AO-16 on a small military genset, and a 4AO-32 on my pull type backhoe.
#5 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted September 27, 2010 - 03:23 PM
Thanks I will look it over.
#6 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted September 29, 2010 - 10:43 AM
How did you make out with the GM setup on the two cyl? Im curious to see if it works
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 25, 2011 - 06:27 PM
jake,
i have two of those 2a016-111 engines, the electronic ignition is bad, the box that bolts to the top of the engine holds the conponets, throw it away, when it go's bad, it's bad, a new assembly can be had from www.saturnsurplus.com/, i fought with mines for weeks before giving up and buying the n.o.s. ignition kit, problem when away, runs like a champ now, this is a common problem with these engines, i want to switch mines to points,
trowel
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 25, 2011 - 06:49 PM
oh, this is a old thread, :wallbanging:
