Ff Issues When Bottom Plowing
72 replies to this topic
#31 olcowhand ONLINE
  • 41,237 Thanks
  • 31,440 posts
Posted February 25, 2013 - 08:29 PM
8.3 gal of fluid each tire.
that would be 89lbs of rim guard or  50lbs of WWF each
Wouldn't 8.3gl water/WWF weigh about 70lbs?
#32 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted February 25, 2013 - 08:31 PM
I thought it was 6lbs for US gal???
#33 olcowhand ONLINE
  • 41,237 Thanks
  • 31,440 posts
Posted February 25, 2013 - 08:32 PM
I put 11 gallons per tire in my 26x12x12's.  Still plenty room for air too.
#34 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
A pints a pound the world around.
  • HowardsMF155 said thank you
#35 olcowhand ONLINE
  • 41,237 Thanks
  • 31,440 posts
 1 US Gallon of water = approx. 8.35 lb (about 3.79 kg)
  • DH1 said thank you
#36 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 08:33 PM
I added 4 gals to my 23x8.5x12.
#37 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted February 25, 2013 - 08:34 PM
http://www.rimguard....e-for-ag-tires/
You guys got it easy down there up here we have to deal with
US gal, IMP gal, liters, pounds, kg, miles, km.
I'm getting a headache thinking about all this.
#38 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted February 25, 2013 - 08:36 PM
I'm going to try for the 11 gals. per tire if I can get it in there.
#39 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 08:38 PM
If you need help I can show you how to do it. I just used a hand pump and a hose.
It took me about 15 min per tire for 4 gals.
#40 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted February 25, 2013 - 09:08 PM
I watched your video, Pat. It looks simple enough. Just not sure on the tubes, how they will take the fluid.
#41 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted February 25, 2013 - 09:39 PM
Kenny, somewhere on here I posted about using a cheapo garden sprayer, like from Home Depot, costs $10.00 or less.  You remove the spray wand from the rubber hose, remove the valve core from your innertube, then push the hose over the valve stem, it's a nice fit.  Pour your fluid in the sprayer, then pressurize your sprayer and the fluid runs on in.  When the sprayer is empty, fill it again.  This way you can keep up with how many gallons of fluid you put in.  Plus, each time you have to open the sprayer, excess air trapped in your tire blows out into the sprayer, which also collects any fluid that runs out.  Keep adding fluid and burping the tire until no more air is coming out.  Then you can still add another gallon or so, and if you really want to push it, you can add fluid until your tire is pretty close to the recommended 5 psi limit, then pull off the tube and re-install the valve core and you are done.
#42 MH81 OFFLINE
Posted February 25, 2013 - 10:15 PM
Don't forget C and F temps :D
#43 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 26, 2013 - 05:08 AM
You shouldn't have any problem with the tubes. Just do it the same way.
#44 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted March 04, 2013 - 05:56 AM
Yesterday, I got the upright pieces drilled for the front box and attached them to the parts tractor. I have to get some angle iron to finish this out. No pics as yet! The FF is in Collinsville at the moment.
The hydraulics are in good condition on this tractor. When I parked it after unloading on Plow day, I left the plow in the air. I was up there yesterday, and the plow was still up. Didn't look like it had settled at all. I went ahead and lowered it to the ground, though!
I did pick up a tire for the plow gauge wheel from HF when I got the winch. And I am looking at a way to add some weight to the back of the plow so it will dig in better.
#45 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted March 05, 2013 - 05:14 AM
 I personally would only add weight to the wheels ,front and rear . It will steer much easier and not kill the moving points on the rest of the tractor.
 The gage wheel will help that sleeve hitched plow big time. Also be sure you get the offset behind the right rear wheel correct orthe plow will steer you no matter what you do because it's so far behind you . MY friend has a WH with a sleeve hitched plow...... he saw me plowing with my Fords and wondered why his didn't plow like they did. I helped him get it all adjusted and now it plows perfectly . No extra weight other than rear wheel weights .  Getting the plow offset correctly and angled was not easy , and required fab work to do it . But it works good now. He only has a hard time with the first furrow, needs to weight the plow to get it started , but once the rear wheel is in the furrow it plows effortless.
