Ff Issues When Bottom Plowing
72 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,499 Thanks
  • 15,397 posts
Posted February 25, 2013 - 02:36 PM
Did I miss it, Where's the video?
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 03:06 PM
It's in the NEOGTA event topic.... HERE
Edited by olcowhand, February 25, 2013 - 03:22 PM.
#18 DH1 ONLINE
DH1
    Electric Tractors
  • 4,929 Thanks
  • 5,432 posts
Posted February 25, 2013 - 06:14 PM
First plow day I went to was Olcowhands last fall and it was a blast. What I've learned up to now.
1 - You need to have a tractor that can pull strong for a long time, good motor and drive-train.
2 - Maximize traction, AG tires or turfs with chains. Loaded rear tires + wheel weights, heavy on the left side, some weight on the front helps to.
3 - Practice before plow day to set up the plow as best you can, then when you get to plow day only make small adjustments.
Moving the plow to the right reduces the cut and lightens the load on the tractor.
My setup on the Massey MF10
- Loaded rear AG tires, 6x12.
- 2 sets of wheel weights on the left rear wheel and 1 set on the right.
- had no extra weight on the front but I think it could use some to improve steering.
- I practiced before and set it up best I could, at plow day I raised the plow 1 turn on the adjuster, thought it was a bit deep, and left it there for the day, it seemed to work.
I'm no expert and I'm sure to learn more at the next plow day I go to.
For your FF like others have said add weight.
Picture from the Brinly 10" sleeve hitch plow manual.
  • MH81, KennyP and HowardsMF155 have said thanks
#19 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 07:11 PM
I'm looking at what I need for next year. Depending on which tractor I get ready, it may be the Mf10. I will have to fix the motor first. But I'm looking at weight adapters so I can run barbell weights.
#20 olcowhand ONLINE
  • 37,711 Thanks
  • 30,338 posts
Posted February 25, 2013 - 07:14 PM
Next year?  You're not coming to my plow day this Fall?  Heck, it's just 11hrs if you don't make a stop to pee!  That's just 5 1/2 hrs each for you & Kenny!  :smilewink:
#21 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 07:16 PM
I could bring the DB and show you how real men plow. LOL
#22 olcowhand ONLINE
  • 37,711 Thanks
  • 30,338 posts
Posted February 25, 2013 - 07:21 PM
Jeff, aka Lauber1 already did that!
  • KennyP and Amigatec have said thanks
#23 KennyP ONLINE
  • 33,166 Thanks
  • 42,646 posts
Posted February 25, 2013 - 07:52 PM
I'm working on a drawing of a front weight box. With the window weights I have, I can adjust fairly easily to conditions. I do have about 30 lbs+/- of barbell weights for the back of the plow. I'll just have to rely on loaded tires for now on the back!
#24 DH1 ONLINE
DH1
    Electric Tractors
  • 4,929 Thanks
  • 5,432 posts
Posted February 25, 2013 - 08:10 PM
Something like this, it could be used as a tool box to carry stuff also.
http://www.myelec-tr...om/GEH-3951.pdf
Black box
This fits GE tractors can be mounted in the rear or front of tractor.
#25 DH1 ONLINE
DH1
    Electric Tractors
  • 4,929 Thanks
  • 5,432 posts
Posted February 25, 2013 - 08:19 PM
What size rear tire on the FF?
#26 olcowhand ONLINE
  • 37,711 Thanks
  • 30,338 posts
Posted February 25, 2013 - 08:20 PM
26x12x12
#27 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 08:22 PM
There you go,
#28 DH1 ONLINE
DH1
    Electric Tractors
  • 4,929 Thanks
  • 5,432 posts
Posted February 25, 2013 - 08:25 PM
8.3 gal of fluid each tire.
that would be 89lbs of rim guard or  50lbs of WWF each
#29 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 08:29 PM
I used WWF in my tires, cheapest way to fill the tires.
#30 KennyP ONLINE
  • 33,166 Thanks
  • 42,646 posts
Here's what I have so far. It is 18" W by 12" D. Not sure how tall as yet, have to stack some of the window weights and see what I need that way. It will hook into the factory blade brackets (Gray). Since it will be out front, it may not take much weight there.
I may not even need it once I get the gauge wheel set up!
