* * * - - 1 votes
Scag Pictures.....
15 replies to this topic
#1 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted February 25, 2013 - 05:20 AM
Well I finally got a lil bit of work done after church yesterday.  I wanted to all weekend but as most of you seen on "morning humor", I had been feeling like warmed over death since Friday.  When I bought the Scag it had a bungee cord holding the gas tank on.  The fuel line was dry rotted and cracked for its entire length and fuel filter was black with build up.  So, I bought materials to make my own straps outa stainless strips that I got from Valu pretty cheap and fitted and trimmed them.  I drilled holes in the back sides and ran 7/16 by 2' bolts thru with washers to tighten them donw.  Looks 10x better than it did and will hold well.  I cut all the fuel line and filter out, replaced all of it and cleaned the tank and carb while I had it all apart.   Sooooo, that's done and ready for the season and I felt some what acomplished this weekend!!
scag.jpg ....new straps
scag1.jpg .....new fuel line and filter
scag2.jpg ....just a pic I took when I brought it home
scag3.jpg ....the picture when it was on CL
#2 Alc ONLINE
  • 6,912 Thanks
  • 7,473 posts
Posted February 25, 2013 - 05:46 AM
Those straps came  out great :thumbs: . Will this be one your going to use just at home or for  business ?
  • Farmlife said thank you
#3 jms180 ONLINE
jms180
  • 1,519 Thanks
  • 1,569 posts
Posted February 25, 2013 - 06:34 AM
That is a job well done on a great machine with a great engine.
#4 welderman85 OFFLINE
welderman85
  • 38 Thanks
  • 53 posts
Looks great nice work
#5 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted February 25, 2013 - 07:44 AM
Its for my business. Commercial use.
#6 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 25, 2013 - 07:47 AM
Nice work! That is a great machine!
:thumbs:
  • Farmlife and tractorgarden'sbabe have said thanks
#7 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted February 25, 2013 - 08:22 AM
Patent that quick!  It looks sharp enough that Skag might be stealing your design for the next mower generation!
Ben W.
#8 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted February 25, 2013 - 08:28 AM
The straps look great.. Seems like the fuel system is often neglected on lawn mowers, you should be set for the summer now.
#9 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted February 25, 2013 - 08:43 AM
The tank straps on the dealer site arent half as strong and dont look that good in my opinion and they wanted $25+ for them. I made both all hardware included for bout $12
#10 KennyP ONLINE
  • 38,498 Thanks
  • 45,981 posts
Posted February 25, 2013 - 08:46 AM
Nice fix with those straps! Ought to last for quite a while! Keep them tight so you don't wear a hole in the tank.
#11 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 25, 2013 - 09:16 AM
Straps look good!  Glad you got something accomplished.
#12 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted February 25, 2013 - 09:37 AM
Its hard to see but i used rubber pads between the tank and straps
#13 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 25, 2013 - 09:53 AM
it turned out great
#14 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 25, 2013 - 09:55 AM
Looks Great!! Skag seems to be a good machine. I would guess 70% of the comercial machines I see running in Des Moines are Skag.
The crew who does our property at the office have two skag riders, one Skag walker and a Ferris walker
#15 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted February 25, 2013 - 10:35 AM
Iv always used scag, ferris or exmark. They all rate bout the same. Great machines but like anything else ya gotta take care of em.
