what is it
6 replies to this topic
#1 muz28901 OFFLINE
muz28901
  • 7 posts
Posted September 26, 2010 - 10:34 AM
P9250049.jpg what make engine is this comes out of a penfield it has a 12 volt starter/alternater in one
#2 Bolens 1000 ONLINE
  • 15,298 Thanks
  • 18,236 posts
Posted September 26, 2010 - 10:50 AM
I'm pretty sure that engine is a Briggs and Stratton.
#3 olcowhand ONLINE
  • 42,479 Thanks
  • 31,828 posts
Posted September 26, 2010 - 11:51 AM
Briggs for sure. As I stated in another post, get the numbers off the flywheel shroud & we can tell you the HP.
#4 muz28901 OFFLINE
muz28901
  • 7 posts
Posted October 02, 2010 - 07:13 AM
we couldn't find any numbers on the fly wheel shourd. he found a guy that had one in his shop said it was 9 hp he has a rebuild kit for and wants $125 for it is that a good price.my dad is a retierd machanic from ups and was wording are they hard to rebuild that guy wants $65 a hour to rebuild it thank you ricky
#5 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted October 02, 2010 - 06:49 PM
The data tag is missing for that engine, picture 3 shows it best, the 4 rivet holes in a square are where the tag was. If/when you pull the head get a bore measurement. I will look in my Briggs book later and see what I can tell by looking that way.
  • muz28901 said thank you
#6 olcowhand ONLINE
  • 42,479 Thanks
  • 31,828 posts
Posted October 02, 2010 - 09:21 PM
I missed the tag holes Peter...sharp eye you have...or very dull ones I have. With the points cover just like my 14 & 15hp, I thought it larger & would have the numbers stamped on the shrouding. I need to look before I leap.
#7 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 03, 2010 - 09:02 PM
the engine looks like my model 14, same carb, intake, shroud, tank, points cover,
flywheel... more numbers should be under the flywheel, (removal required to see).
I'm just recently collecting info on the model 14, so don't know it all, yet, but I
thought they range from 2.5 to 6.6 HP
the tractor looks like a sears unit... google old sears lawn tractor...select "images"
good luck
