Mf 12 Variable Speed Transaxles
5 replies to this topic
#1 gismo OFFLINE
gismo
  • 2 Thanks
  • 14 posts
Posted February 24, 2013 - 08:10 AM
Hi  I would like to know where I could fine a rebuilt transaxle for my mf 12 variable speed.  Hard getting into gear sometimes and sometimes pops out of third.Just a detent ball problem?,and if so is it much of a job to fix. Thanks in advance  GISMO
Edited by gismo, February 24, 2013 - 08:11 AM.
#2 boyscout862 OFFLINE
  • 15265 Thanks
  • 10024 posts
Posted February 24, 2013 - 09:21 AM
Welcome to GTT. There are a dozen pages of manuals for MFs in the Manual Section. Look through and you can download the manual that you need.
  • gismo said thank you
#3 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 24, 2013 - 09:32 AM
Gizmo, the hard to get into gear... Is that a grinding issue?
As for the pop-out, yes it is normally a detent ball issue. They are still available thru John Deere parts (they used the same tranny in the 110 & 112 tractors.
:welcome: to GTTalk!
#4 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted February 24, 2013 - 10:10 AM
Member "NutNdun" posted a very nice write-up of his transmission tear down and rebuild.  I had suggested that he make it a sticky or an article, but I don't know if he did.  I'll try to see if I can find it.
Ok, here it is:
http://gardentractor...ission rebuild
Edited by HowardsMF155, February 24, 2013 - 10:14 AM.
#5 gismo OFFLINE
gismo
  • 2 Thanks
  • 14 posts
Posted February 24, 2013 - 10:55 AM
Yes sometimes it may grind a little,  is that an ajustment issue ?
#6 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 24, 2013 - 12:22 PM
That is usually a combination of the brake needing adjusted and possibly the varidrive too.
Start with the Brake.  make sure the clutch is all the way down and the brake is engaged before shifting.  Never shift on the fly.
