need help with 2 wires
3 replies to this topic
#1 muz28901 OFFLINE
muz28901
  • 7 posts
Posted September 26, 2010 - 09:46 AM
P9250038.jpg my dad just bought a penfield the man said it ran and we are wonreding where this 2 wires go belive it's a bs eng. has starer/gen in one can any help us:confuse:
#2 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted September 26, 2010 - 11:29 AM
Yes, it's a Briggs. One wire to points, the other is grounded to kill ignition to shut down.
  • muz28901 said thank you
#3 muz28901 OFFLINE
muz28901
  • 7 posts
Posted September 26, 2010 - 11:34 AM
does it matter what wire goes where and thanks
Edited by muz28901, September 26, 2010 - 11:34 AM.
spelling
#4 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted September 26, 2010 - 11:48 AM
No, doesn't matter as they both go to the same spot on the mag. There will be numbers stamped into the flywheel shroud. Could be on either side, under the carb intake area or under the starter on other side. Likely has lots of paint over the numbers, but will be there. Can ID the engine & HP if you can get the #'s.
