Steering Linkage
7 replies to this topic
#1 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted February 23, 2013 - 12:59 PM
Does anyone have any P.N. for the ball stud on the steering linkage? These screw into the spindles.
If I can't find the studs I'll opt for a ball joint assembly for both ends. Just need to know the thread sizes
and lengths. I figure after 35 years there has to be some wear. I might as well replace everything while I have the tractor completly torn apart.
#2 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted February 23, 2013 - 03:14 PM
I think this is  what your looking for ?  The darker picture is on 1968 Jim Dandy the brighter one is on a seventies PK . On both of those there is some adjustment where the cotter pin holds the cup on maybe yours are different or worn too much ?  Not sure where you would have to go for factory replacement ones .
  • pharmer said thank you
#3 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted February 23, 2013 - 03:43 PM
Yes that's it. I want to replace the ball stud that screws into the spindle. I'm sure someone here must have done it sometime. I haven't pulled mine apart yet to check, but I'd they are worn I want to find a source. I guess it's called "planning ahead"
#4 icpik OFFLINE
icpik
  • 23 Thanks
  • 40 posts
Posted February 23, 2013 - 04:25 PM
Mission should have the part.  http://powerkingtractor.com/
Jerry Frank may have used parts.  http://powerkingtractorbarn.com/
Don Hayes
  • Alc and pharmer have said thanks
#5 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted February 23, 2013 - 06:43 PM
I looked up the part number, the 1975 manual has it listed as "KNUCKLE, tie rod" part number "03-6703" and ".50-20 Threads." That manual is also in the manuals section.
#6 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted February 27, 2013 - 04:10 PM
Don't think you will find the old ones with pins and adjustment anymore. Sometimes the balls are more worn one way than the other and if not too bad can turn them to have better side to the center of tractor and then adjust the spring and cap tighter. OR, just go buy new style ends and make a new rod to update. Those are common ends that don't adjust now. McMaster-Carr has some on sight with diff styles. Easy to use site. Size is common, just pick right male and female ends. Recoomend at least 1/2" rod OR get bolts to weld on the end of 3/8" pipe and have beefier rod. I did that to mine with loader. Assemble new ends to bolts and only cut the pipe to length after trying it on the tractor. Weld the heads to the pipe. One can be welded to assist in trying them out, other wait till measured. Make sure you get bolts with enough threads to make adjustments. I put my joints halfway on the bolt threads to take dimensions. My local ACe store has those joints or local GT places should have,, maybe a good farm store? Expect to pay $15 to $20 each.
#7 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted February 27, 2013 - 08:52 PM
Yeah. Looking forward to some decent (no snow-no rain- 40 +degrees) this weekend . I'm going to start taking the front axle off and see what needs replacing. We have a McMaster Carr account at my work so I will probably look into getting replacement ends through there. I know they carry the bushings for the spindles also.
#8 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted March 03, 2013 - 01:46 PM
Pulled the front axle off today. I will be replacing both ends with a one piece type w/ grease fittings. The spindle bushings will be replaced also, along withe the needle bearings for the pivot pin. Everything is going to shot peaned to strip the paint. All new wheel bearings too. Do it right. Do it once.
The engine block is at the machine shop getting bored/honed so hopefully I can get that back together in the next few weeks.
Edited by pharmer, March 03, 2013 - 01:53 PM.
