Longer Fuel Tank Shut Off Valves ?
11 replies to this topic
#1 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 23, 2013 - 07:47 AM
Does anyone know of a source for shutoff valves, that have
a longer neck between the thread, and valve body?
I keep running into the problem of these being too short, when
the tank sits on a base, and by the time you put a foam cushion
inbetween tank and base, it just doesn't work.
#2 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted February 23, 2013 - 07:57 AM
If the tank is clean inside, how about a brass coupling and short nipple?
  • IamSherwood said thank you
#3 Michiganmobileman OFFLINE
Posted February 23, 2013 - 08:01 AM
That was my first thought too, not sure if they are available longer, that is a standard 1/8 inch pipe thread isnt it?
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted February 23, 2013 - 08:49 AM
The couplings are still available at my local Ace.  Lowes used to have them, but I haven't gotten anything like that there for awhile.
Ben W.
#5 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 23, 2013 - 09:03 AM
My thought also. I think Lowes or an Air Compressor parts store will have 1/8 pipe connectors. That way you can put the valve whererever you want. Will, I may have some in my massive supply of junk plumbing parts if you can't find one-Lee
#6 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted February 23, 2013 - 09:28 AM
anywhere that sells a good selection of brass plumbing fittings has them. I got mine at Menards, but Lowes,Home Depot, etc. have them too.
#7 brahlf OFFLINE
brahlf
  • 11 Thanks
  • 24 posts
Posted February 23, 2013 - 10:21 AM
Where do you get one that is in the picture?  I checked with Ford and they didn't have them anymore.
Thanks
#8 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted February 23, 2013 - 01:12 PM
Will, Check this link out. Not sure any will work but some do have a longer neck.
http://ihccw.com/tanks.html
#9 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Thanks
Places like this have them.
http://us.ebid.net/f...CFUWd4AodhBEAFg
#10 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted February 23, 2013 - 01:24 PM
Use one of these
Either one of these
And one of these
No there not original but they work.
#11 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 25, 2013 - 06:32 AM
When all else fails, try a Fluid Power Distributor who deals in industrial pneumatic valves cylinder etc. They will usually carry
a line of fittings, including barbed or push-lock connectors etc. You'll have to check compatibility of course, but your choices
will be vast.
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 25, 2013 - 08:20 PM
I don't know about all gt's but I removed the rear shield that the hydraukic lines feed through ( JD314 )and yoiu can reach the valve with no problem
