Flywheel Weight
7 replies to this topic
#1 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted February 22, 2013 - 09:44 PM
  how do i go about adding weight to my steel flywheel
  • 14,889 Thanks
  • 15,514 posts
Posted February 22, 2013 - 09:50 PM
Is it out of balance, or are you trying to balance the engine?
#3 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted February 22, 2013 - 09:53 PM
ive got a light weight flywheel like 19lbs want to make it to at least 22 maybe 23
  • 14,889 Thanks
  • 15,514 posts
Posted February 22, 2013 - 09:59 PM
The only way I know of is to have weights welded on and then get it balanced.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,122 Thanks
  • 5,084 posts
Posted February 22, 2013 - 10:25 PM
What type of ignition? What ever you do, your going to have to distribute the weight even around the wheel. A machined ring around the outside would be easy if there's room. It will need balanced when your done.
#6 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted February 22, 2013 - 11:40 PM
I'd just get another one, usually you can pickup a used one reasonable off one of the pulling for sale sites
#7 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 23, 2013 - 01:13 AM
What are you using it for? stock or pulling etc? If its for pulling you can buy aftermarkets fly wheels for those. If not id get another one or have a machine shop make you a heavier one so that way it doesnt explode I dont think youve ever seen a flywheel come apart its scary!
#8 Alc ONLINE
  • 7,259 Thanks
  • 7,598 posts
Posted February 23, 2013 - 07:44 AM
Is the reason for adding weight to the flywheel for "pulling "?   If  your just looking for more rotating mass ,maybe you can add a large pulley on it , Not knowing what your working with ,my PK  have a pretty heavy pulley mounted on the flywheel side and a very heavy pulley used for the drive on the output.  Unless your in a stock class and are trying to bend the rules by making it look stock lol
