Question
8 replies to this topic
#1 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted February 22, 2013 - 10:39 AM
Maybe a stupid one. What was the reasoning behind the "tube" frame on my FORD LGT100?
I can't even spell "question" right.
Edited by crittersf1, February 22, 2013 - 10:40 AM.
#2 boyscout862 ONLINE
  • 10,810 Thanks
  • 8,094 posts
Posted February 22, 2013 - 11:08 AM
My Ford LGTs and Bolens are tube frames. The tube is more stiff in every direction than an angle iron per pound. As an engineer, I know that a tube is theoretically better for many  applications. Unfortunately, erection and connection costs are often higher. As a firm believer in KISS, I design for the easier fabrication and erection. I've saved alot of money on projects this way. I comes down to the designers preferrence and imagination.
Edited by boyscout862, February 22, 2013 - 11:50 AM.
  • Alc, KennyP, CRFarnsworth and 2 others have said thanks
#3 KennyP ONLINE
  • 32,297 Thanks
  • 42,065 posts
Posted February 22, 2013 - 11:15 AM
Sounds like a good answer to me! It is harder to bend a tube.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted February 22, 2013 - 11:49 AM
That was my thoughts, just wanted some one elses thoughts.
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted February 22, 2013 - 12:01 PM
Boyscout862: that makes a lot sense. Now being a racing fan is the reason tubes are used in racecar construction that the tube frames are also lighter that square material  and structured beams?
#6 boyscout862 ONLINE
  • 10,810 Thanks
  • 8,094 posts
Posted February 22, 2013 - 12:28 PM
If you are talking about protection during a roll, the round tube gives you the same strength in every direction. I haven't used my steel manuals in several years. I will try to find one later today to give you an example.
  • A.C.T. said thank you
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 22, 2013 - 03:54 PM
I think someone was lost for a reply there.
Dick
#8 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted February 22, 2013 - 04:03 PM
The strength is superior with tubes. Glad to meet another LGT 100 owner!
#9 boyscout862 ONLINE
  • 10,810 Thanks
  • 8,094 posts
Posted February 22, 2013 - 05:25 PM
I looked up an example: 2" round has the same weak axis strength as 2" square but the square weighs 16% more. Since they want to keep the weight down the tubes make sense.
