Bush Hog St-32 Tiller Restore
44 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted February 21, 2013 - 09:44 PM
I have a possible source on the 10 tooth, what diameter shaft?
So you need a 10 tooth, for 1" shaft with weld on hub?
#17 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 21, 2013 - 09:48 PM
Yep, a mighty tough order to fill huh!
#18 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 21, 2013 - 09:49 PM
Nope, it's 20:1 we need, right? :smilewink:
Something like that!  :bigrofl: (inside joke)
#19 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 22, 2013 - 06:17 AM
I'm wondering if the dual drive was meant to strengthen the tyne shaft. It might have been an attempt to improve on the more typical centre drive for the tynes. I looked at my usual supplier for sprockets and hubs and 12 teeth is as small as they go for a weld on hub in #40. That's likely why they used a single machined hub/sprocket. They were dealing with trying to get the chain drives as compact as possible while still having large enough chain and sprockets to deal with the power and have a long lifespan. This is an interesting restore Daniel. I'm looking forward to seeing it come together.
#20 Alc ONLINE
  • 7,224 Thanks
  • 7,578 posts
Posted February 22, 2013 - 06:36 AM
Would a sprocket like one of these work ? Might have to machine the shaft .
http://www.gokartsup...om/sprocket.htm
  • olcowhand said thank you
#21 boyscout862 ONLINE
  • 13,545 Thanks
  • 9,426 posts
Posted February 22, 2013 - 07:55 AM
Can you use the 10 tooth from here  https://www.surplusc...ns&keyword=PH40 and just bore it out and cut a new key way? Good Luck, Rick
  • olcowhand, Alc and IamSherwood have said thanks
#22 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 22, 2013 - 09:42 AM
Thanks Al, I think one of those will work, and it's 10 tooth, so I'd only have to repair the one, leaving the other side OE.   :thumbs:
I should be able to machine the OE hub body for this sprocket's hub to slide into & weld in place.
3/4" SPROCKET 12 TOOTH #41/420 #40,41,420 CHAIN
#23 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 22, 2013 - 09:44 AM
Wow....even better!!!!!!   Just $4!  Thanks so much guys!  I hadn't taken/had the time to do any searching yet, but you've done it for me!  :thumbs:
#24 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted February 22, 2013 - 09:50 AM
Glad the guys found something usable for you, Daniel. With your abilities to rework either one, you should be able to fix it right up.
#25 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 22, 2013 - 12:29 PM
No pics yet, but took a few minutes before lunch to get the old bearings off the tine shaft.  I just used a .045 cutter wheel on my angle grinder to slice them on one side, then use a hammer to break them up.
  As to the OE 10 tooth drive sprockets....turns out once I cleaned one up that all they are is a 1/2" bore 10 tooth sprocket welded to the shaft hub!  So I'm ordering a pair of 10 tooth 1/2" bore sprockets from Surplus Center, along with a 10' roll of chain, a few connector & half links, and they have the bearings I need for the tine shaft, all at SUPER prices!   Just confirmed the order!   :dancingbanana:
  • KennyP, sacsr and boyscout862 have said thanks
#26 KennyP ONLINE
  • 40,866 Thanks
  • 47,088 posts
Posted February 22, 2013 - 01:42 PM
That's great news, Daniel! You might even get to try it out this spring!
#27 Alc ONLINE
  • 7,224 Thanks
  • 7,578 posts
Posted February 22, 2013 - 03:05 PM
Good to hear you got some  sprockets coming .  Know you said you might not use this only for show but I got to thinking of what the guys here about breaking the gears on my PK  tiller . Anyway it would be nice if you could drill the sprockets and shaft and use a shear pin drive instead of welding , it might save the gearbox if it was ever used in a rocky area
#28 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 22, 2013 - 03:32 PM
It is going to have a slip clutch installed on it.  I actually have a NOS OE Bush Hog pto slip clutch that I got from my good buddy Scott (sascr).  It is for use with the D4-10 pto, and that's what I want it to mount to anyway.  I'll have to build a new tiller hitch bracket for this tiller to fit the D series though.  This tiller as used on a JB tractor, which uses belts for the rear pto, which were supposed to act as a slip clutch.  But twin belts will put through a lot of power before they slip.  The OE slip clutch is adjustable, so I can set it to slip easy enough to never fear damage should I use it & snag a rock.
#29 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted February 22, 2013 - 04:01 PM
I'm glad you found out what you needed. :thumbs:  I called my bearing house and got a price on a 10t. X 1/2" bore and was going to bore it.
Can't wait to see how it turns out ! :D
#30 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted February 22, 2013 - 08:11 PM
Today I got one of the large sprockets off the tine shaft that I had to cut in half to remove.  Had to put a little acet. torch heat to it while in the press, then it moved easily.  I won't have to remove the other sprocket on the other shaft half, as I can slide all the bearings & stuff in place from one end after welding the shaft back together & turning it true on the lathe.  Turns out the broken gearbox shaft failed due to it having a hold bored into it in a spot that the hole served no purpose.  This shaft must have been used in other applications where the hole did serve a purpose.
