Lawn Roller
10 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted February 21, 2013 - 06:06 PM
I have a old lawn roller. And i was wondering i had  a freind tell me that i could fill it with used oil insted of water. That way it wouldnt freeze, and prevent rust. Anybody tried this?
  • Texas Deere and Horse, boyscout862 and larryd have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted February 21, 2013 - 06:10 PM
Good idea :thumbs: but if it ever started to leak, you would have a real mess to clean up.
  • boyscout862 and larryd have said thanks
#3 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Should work, but if it leaks you will have a hazardous spill site, and oil is lighter in weight than water..
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted February 21, 2013 - 06:20 PM
I would probably use windshield washer fluid, it's a bit lighter than water, but it shouldn't freeze.
  • larryd said thank you
#5 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted February 21, 2013 - 06:34 PM
I just fill mine from the gutter downspout in the spring and drain it in the fall. Its not a big deal.
  • Texas Deere and Horse, Arti and larryd have said thanks
#6 Kurtee OFFLINE
Kurtee
  • 585 Thanks
  • 467 posts
Posted February 21, 2013 - 07:41 PM
I think that the water fill and dump in fall is the best option. Oil could cause a whole new issue. Or you could fill it with dry sand.
#7 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted February 21, 2013 - 09:25 PM
Just do like the other 99½ % that own one (I'm included) , leave it behind a shed and forget about it :bigrofl: :bigrofl:
P.S. FIL was downsizing the homestead years ago, gave it to me as "ever used" , I used once, grass seed, parked 8 years now. :D
  • Texas Deere and Horse and boyscout862 have said thanks
#8 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 22, 2013 - 08:45 AM
fill it with cement. works great and will never come out
#9 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted February 22, 2013 - 09:58 AM
My buddy has a 55 gal steel roller filled with oil, shouldn't ever have to worry about rusting from inside out.
#10 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted February 22, 2013 - 12:41 PM
I have made a few out of 55 gal drums. The ribs will eventually wear down enough that the sand will leak out. Put me on the list of guys that never use them. Other than smashing down mole hills, they dont do much good. Even filled with sand, I cant tell much of a difference. The only time they work is right after a good rain or spring thaw, but then you just make ruts trying to pull them around.
  • twostep said thank you
#11 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted February 22, 2013 - 02:32 PM
This one is the size of a 55 gal drum not made out of one, it's more like a large pipe, smooth all around. I would hate to try to move it.
