Transmission Fan
14 replies to this topic
#1 chrisk OFFLINE
chrisk
  • 2 Thanks
  • 13 posts
Posted February 21, 2013 - 11:17 AM
has anyone replaced the transmission fan yet?  curious what i am in for?
#2 boyscout862 OFFLINE
  • 10,502 Thanks
  • 7,926 posts
Posted February 21, 2013 - 11:38 AM
We need to know what tractor. Pics will help too.
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 21, 2013 - 12:23 PM
If you have a service manual I would suggest following the instructions.
Dick
#4 chrisk OFFLINE
chrisk
  • 2 Thanks
  • 13 posts
Posted February 21, 2013 - 12:36 PM
sorry - its a GT 17
#5 shorty ONLINE
shorty
  • 4,193 Thanks
  • 4,418 posts
Posted February 21, 2013 - 09:19 PM
I had to replace the fan blade on my S-16 several years ago. I think that mine had a drive shaft upgrade at some point, may be what the GT series used. If I remember right, I loosened the front connection, just the shaft lock. Then I had enough play to remove the rear coupler and was able to lift the shaft far enough to install the new fan.
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted March 26, 2014 - 09:26 AM
I am curios about this as well.  I picked up a GT16 the other day and noticed that the blades on the fan were messed up so enough so that the fan needs replaced.
Where do you get the new fan at ?
And, do they just slip onto the driveshaft or somehow held in place on the driveshaft with something?
#7 shorty ONLINE
shorty
  • 4,193 Thanks
  • 4,418 posts
Posted March 28, 2014 - 08:05 PM
I think I had gotten mine at a local farm supply store. There is a spring that holds it against a clip. If something would get lodged into the fan, it would slip.
#8 1964Deere OFFLINE
1964Deere
  • 248 Thanks
  • 291 posts
Posted March 30, 2014 - 01:36 AM
I took mine apart on my S-16H last summer, And like shorty said, once you loose the shaft (a few bolts on the flange) you can take the bolts off the fan and it comes right off.
#9 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted March 31, 2014 - 09:00 AM
I guess now I just need to find a source for the new fan blade.
#10 Markski OFFLINE
Markski
  • 21 Thanks
  • 27 posts
Posted September 25, 2014 - 05:40 PM
Doesn't Ariens have them anymore? I've changed them in the past but it's been a while. I don't recall it being a terrible job.
#11 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted September 29, 2014 - 02:08 PM
I did finally get this done, the part was found at Jacks.
#12 dodge trucker ONLINE
dodge trucker
  • 1,555 Thanks
  • 2,027 posts
Posted October 21, 2014 - 06:02 AM
I just ordered one 2 days ago from Jacks small engines it was like $18. so anyone that handles Ariens parts should be able to get it as well. IDK if it can be had besides thru Ariens.   but I will say this; Judging by prices listed on some Briggs parts and Kohler parts that I have recently gotten via "other" online sources, if you can find it elsewhere it will probably be cheaper than thru Jacks.
the good thing is that he did have it.
I looked for it at the other sources (that I use, anyhow) online and they, at least, did not carry Ariens parts. of 3 places (total) that I checked, Jacks was the only place that had Ariens parts.  As many tractors (of all makes) that run via hydrostatic drive, I would not think  that Ariens was the only manufacturer that used that particular fan  but I could be wrong.
#13 KennyP ONLINE
  • 31,326 Thanks
  • 41,545 posts
Posted October 21, 2014 - 07:02 AM
Post some pics of that fan before it goes on, please! It may be of use to folks with other brands looking for these fans.
  • shorty said thank you
#14 dodge trucker ONLINE
dodge trucker
  • 1,555 Thanks
  • 2,027 posts
Posted October 22, 2014 - 06:22 PM
pix doubtful,  but I got the new fan in the mail today.... it is black, (one on it now is white/off white, I could care less about that) The hub itself where it rides on the shaft is thinner plastic than I thought it may be, has a molded in "collar" shaft hole ~5/8-3/4" collar is ~1-1/2" ID, 5 blades and is marked (molded into the center)  "THORGREN    VALPARAISO, IN"   Hey that's only an hour from here! though I have never heard of that company) It also says "7  CW"   within the hub. I don't have a tape handy but I'm guessing it is ~7" diameter and apparently meant to draw air when spun clockwise...
this info may help someone else find an alternate source, rather than having to pay the Ariens middleman...
Edited by dodge trucker, October 22, 2014 - 06:24 PM.
#15 markoor OFFLINE
markoor
  • 7 Thanks
  • 13 posts
Posted November 03, 2014 - 01:40 PM
I can post fan pics if someone needs them. I just took 2 of the three nylon spacers out of mine cuz it was making the drive shaft end hit my floor pan. Not really sure whey the original owner did that. I wonder if I even need the nylon washers in there or if I can bolt it up without. I'm assuming its just a vibration dampening thing.
