Getting Rid Of Old Gas Smell
15 replies to this topic
#1 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted February 20, 2013 - 02:58 PM
Just wondering if anyone has a sure fire way to get rid of the smell of old gas. I'am helping my Grandson fix this old snowmobile he bought and the old gas smell is getting to us.Everything was OK untill I grabbed the fuel line that goes into the gas tank It started leaking old gas due to the rubber gromet being rotten.We had to drag the machine outside due to all the old gas leaking over everything..We can't work in the heated shop on account of the smell over powering us.Was kinda hoping to beable to pour something into the gas tank as well as were lots has leaked onto the machine itself.Its sitting on a sleigh that we move it around on and the old gas has gotten over it as well.Using water and ??  in freezing temps won't work so just asking if anyone has any ideas.Right now its on hold due to the smell.Of course you can imagine how happy he is with me right now that I won't bring it back inside to work on.LOL .I'll have to search other sources for the rubber gromet seeing Ski doo no longer has them.I need to get rid of the smell more so then anything.Thanks Larry
Edited by massey driver, February 20, 2013 - 03:38 PM.
  • JRJ said thank you
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1170 posts
Posted February 20, 2013 - 03:13 PM
Larry I had a similiar problem with my GT235 right after I got it home. To make a long story short I found a rubber bushing into the gas tank where the gas line join it. I replace the bushing ($2.55) and the gas smell was gone. Hope yours can be as simple.
Just check the gas lines real good at all connections.
Dick
Edited by JRJ, February 20, 2013 - 03:14 PM.
#3 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted February 20, 2013 - 03:33 PM
white vinegar, it's cheap and the results will surprise you. For the shop leave a few wide bowls of it to get rid of the smell.
We use it a lot to remove smell (smoke) in houses.
  • massey driver, Texas Deere and Horse, boyscout862 and 2 others have said thanks
#4 boyscout862 ONLINE
  • 15091 Thanks
  • 9969 posts
Posted February 20, 2013 - 04:09 PM
If the smell is strong it still could be volatile. Be careful of a fire.
#5 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted February 20, 2013 - 04:19 PM
I'll second the white vinegar.
Ben W.
#6 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted February 20, 2013 - 04:28 PM
That's hard to get rid of in a short time. I use Kitty Litter on diesel spills to soak up the fuel and it also seems to deal with the odour. I'm not sure if it would work on gas spills though.
#7 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted February 20, 2013 - 05:55 PM
I use smoke to get rid of the stink from dead mice and birds in the shop. I have a small wood stove that I start up and pull the plates off and throw on a few big chunks of wood to fill the shop with smoke. It takes a couple of days before the smoke smell is mostly gone, but you dont notice the dead smell during that time.
  • massey driver and boyscout862 have said thanks
#8 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted February 20, 2013 - 06:21 PM
If it has leaked into the cement, the vinegar may help. I have also had luck getting it off hands or out of gloves/clothes with borax, water and head-n-shoulders... Might be something to consider when washing stuff off.
Coffee grounds do a decent absorption of odors.
#9 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 10226 Thanks
  • 5243 posts
Posted February 20, 2013 - 09:16 PM
Go out and find a skunk. Capture said skunk.  Take skunk into shop and frighten skunk.
You won't smell any old gas.
:bigrofl:
OK, that might not be the best solution ~~~~~~~
  • MH81, IamSherwood, boyscout862 and 1 other said thanks
#10 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted February 20, 2013 - 10:27 PM
If you ever have a large diesel spill after the "kitty litter" use good old fashion powdered lime, it wicks it out of concrete very good.
Put it down and after it turns color just sweep it up, repeat until no color change, if smell is still there, follow with a 5 gallon bucket of warm water and dish washing detergent, just put it on spill area and let it dry. I've done 100's of spills over the years, and these little things work, with out fancy chemicals which are $$.
  • massey driver, Texas Deere and Horse, JDBrian and 1 other said thanks
#11 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted February 21, 2013 - 05:14 AM
Thanks John. I have one of those flo and go nozzle rigs to put fuel into the 2320. The tank opening is on the top of the hood which is not a good spot for it if you aren't pumping the fuel. I put 2 20L (5.3gallon) tanks up on a shelf about 6ft high and use the nozzle to siphon the gas in. In the cold it sometimes sticks and won't shut off. This happened the other day and resulted in a bit of a mess. I find the Kitty Litter works well if you get it on right away. I always have it handy in the garage. I'll give the floor the treatment you recommend this summer to get it good and clean.
#12 Canawler OFFLINE
Canawler
  • 1954 Thanks
  • 1806 posts
Posted February 21, 2013 - 11:56 AM
I told my wife there's a thread about getting rid of old gas smell.  She's following it with great interest. :smilewink:
#13 bh115577 OFFLINE
bh115577
  • 444 Thanks
  • 240 posts
Posted February 21, 2013 - 12:20 PM
If the vinegar trick doesn't take care of it, which it should, you can get a spray can from the local HVAC supply house. It is for removing the smell of heating oil in a home if it leaks and I unfortunately know that it works very well. It's been about 10 years since I bought it but the spray was less than $10 I think.
This isn't the exact product I bought but it looks to be something similar.
http://www.zorbx.com...about_zorbx.asp
Edited by bh115577, February 21, 2013 - 12:25 PM.
#14 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted February 21, 2013 - 09:57 PM
 odorgspy.jpg , is what you most likely have, it works on fresh fuel oil. Use it just about every day for work. More of a mask than removal, long term.
For big spills my outline above works, don't ask why I know, after 25 years in the heating business :smilewink:
  • boyscout862 and bh115577 have said thanks
#15 DougT OFFLINE
DougT
    Dog Approved
  • 8363 Thanks
  • 5749 posts
Posted February 21, 2013 - 10:22 PM
On heavy oil stains at the shop, I use stoddard solvent. Put some on the floor and mop it around, then put oil dry on it. Go back later and sweep up the oil dry. It wil be reusable and the floor will be nice and clean.
