What Type Of Paint For Gas Tanks?
8 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted February 19, 2013 - 07:23 PM
What type of rattle-can paint do you like to use on gas tanks?  Enamel, acrylic enamel, farm & implement, urethane, automotive, etc?  Do you clear coat &, if so, what with?
What brands do you like / dislike?
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,787 Thanks
  • 5,091 posts
Posted February 19, 2013 - 07:35 PM
The main thing is do not use primer under the paint on a gas tank.  Its usually the primer that is so soft that the gas dissolves it on contact.
  • Alc and New.Canadian.DB.Owner have said thanks
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 19, 2013 - 07:51 PM
And having that said, you now know that is a No-No. A lot of times it all depends on the brand of tractor you are working on.
Dick
Edited by JRJ, February 19, 2013 - 07:51 PM.
#4 olcowhand ONLINE
  • 42,886 Thanks
  • 31,937 posts
Posted February 19, 2013 - 08:19 PM
Acrylic enamel is more resistant to gasoline.
  • Alc, boyscout862 and New.Canadian.DB.Owner have said thanks
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 20, 2013 - 12:24 PM
I did not realize that. So do you just paint bare metal on the gas tank with no primer? Or do you not strip all the paint off the tank to begin with?
#6 Gtractor ONLINE
Gtractor
  • 9,787 Thanks
  • 5,091 posts
Posted February 20, 2013 - 07:51 PM
I usually take the tank clear to bare metal by blasting and then just paint it that way.   The factory primer is a whole different story.  Factory primer will stand up to gasoline just fine and much better than any replacement stuff, especially rattle-can primer. Any spilled gas can still dull the new paint but as long as it doesn't lift the paint,  the shine can be brought back with a lil buffing.
  • LTD and New.Canadian.DB.Owner have said thanks
#7 olcowhand ONLINE
  • 42,886 Thanks
  • 31,937 posts
Posted February 20, 2013 - 07:58 PM
I've always used primer on tanks & never had an issue with paint coming off, but then I use acrylic enamel automotive paint with hardener shot from a gun.  Back when I used all rattle can over 35 years ago, paint coming off fuel tanks was a big issue.  Another good reason to go to gun painting.
#8 dodge trucker ONLINE
dodge trucker
  • 2,807 Thanks
  • 3,439 posts
Posted March 02, 2013 - 08:29 PM
I wonder if this also applies to hydraulic fluid, as well as it does for gas?
#9 HowardsMF155 ONLINE
  • 2,959 Thanks
  • 3,016 posts
Posted March 02, 2013 - 09:13 PM
I'm curious about the longevity of epoxy paint for these applications.  I used some years ago and painted some radio control boats that I built.  In that application it has held up well over the years.
