* * - - - 1 votes
Water In The Oil?
28 replies to this topic
#16 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted February 20, 2013 - 09:32 AM
after reading this tomorrow when im in the shop ill take a look at the oil in the cub before i change it since it has no hr meter im just gonna change it twice a year
#17 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted February 20, 2013 - 06:25 PM
Just for laughs (also called "research"!:D), see if you can sample the oil at or near the bottom of the sump.  Maybe a thin copper tube down the dip stick hole or into the oil fill.  Get a little into the tube from the bottom, put a finger over the top end and pull the tube out quick.  The water will be on the bottom of the sump. (Now, this sounds like such a good idea I might just have to try it myself tonight!:D)
  • backwoods and boyscout862 have said thanks
#18 HDWildBill OFFLINE
  • 8,984 Thanks
Posted February 20, 2013 - 07:20 PM
Just for laughs (also called "research"! :D), see if you can sample the oil at or near the bottom of the sump.  Maybe a thin copper tube down the dip stick hole or into the oil fill.  Get a little into the tube from the bottom, put a finger over the top end and pull the tube out quick.  The water will be on the bottom of the sump. (Now, this sounds like such a good idea I might just have to try it myself tonight! :D)
Don't laugh but that is how they take oil samples on some jet engines.  The sample kits come with a plastic straw.
#19 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted February 21, 2013 - 07:09 AM
An just how much do one of those fancy jet engine oil sample kits cost? ill grab a straw or a piece of tubing an check it when i meander out to the shop for the day. its a simple yet good way to check thanks for the tip
#20 HDWildBill OFFLINE
  • 8,984 Thanks
Posted February 21, 2013 - 10:08 AM
Those kits have to be pristine clean because the oil that is pulled out of the tank is sent to a lab where it under goes several different test's and if any of those test's go past the threshold that engine is pulled and sent in for repairs.  For what you all are doing a regular straw will work just fine.
#21 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted February 21, 2013 - 11:33 PM
Just go easy on that straw!  Crankcase oil doesn't taste anywheres near as good as diesel fuel!:D
  • HDWildBill said thank you
#22 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted March 05, 2013 - 08:59 PM
Well, checked the oil today (after setting for a few days) No water :rocker2:  This is after a 9 mile round trip to the Rattlesnake roundup.
And a 1/2 day or so of pulling last weekend (My Daughter was being easy on BMP) I was pulling wheeliees on some of these). Way Fun!
No more moisture :dancingbanana:
Will be working on the Cedar again this weekend. PS Oil is still at the FULL mark!
#23 KennyP ONLINE
  • 40,954 Thanks
  • 47,136 posts
Posted March 06, 2013 - 07:12 AM
That's great news, Larry! Glad the Ford is getting a good workout. Are you going to burn the wood or just stack it as a habitat for animals?
  • larrybl said thank you
#24 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted March 06, 2013 - 07:01 PM
It's being stacked for now. Will use some for the small (8 foot) bond fire pit (If the wind ever dies down).
#25 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 07, 2013 - 08:56 AM
did u drive it the 9 miles.
#26 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted March 07, 2013 - 08:19 PM
Yup, Nice ride, even got up to around 25 mph in netrual on some of the gentle slopes.
#27 KennyP ONLINE
  • 40,954 Thanks
  • 47,136 posts
Posted March 07, 2013 - 08:31 PM
BMP looks a bit lonely out there on the highway! Glad he made the trip without any issues!
#28 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted March 07, 2013 - 08:46 PM
I think two bicyclesest, a couple pickups, and one car passed me there and back. Don't get me going on the Story about Hulk I (the first Hulk I had). I took it for a ride to town and while cruzing was wave down by a "good ole boy" and we sat on his porch enjoying some spirits, (I don't do well with spirits) well on the way home I broke down on this same road and I had the Wife tow me home (I was 3 sheets in the wind, and she was pi$$ed) needless to say I had to reline the brake as I stood on it all the way home. I think I looked like a sparkler attached to the back of the truck.
#29 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 08, 2013 - 08:43 AM
thats amazing that u could do that. i might try it one day
