Jd430 Weird Speed Changes...fixed :-)
34 replies to this topic
#16 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 18, 2013 - 09:43 PM
Calf and new mooma doing okay?
Calf is in several pieces, but is feeling no pain.  Momma is good at this time, but we have to watch her very close....read more HERE
  • Cat385B said thank you
#17 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 19, 2013 - 04:52 PM
Almost finished with the repairs, well, the repairs are finished, but I have yet to put the wheels, tank, and fender pan back on, then the deck.  I have to feed the cattle now, but I may get the fuel tank & wheels back on so I can give it a test drive.  I'll try to get a few more pics of what I did also.
  • Texas Deere and Horse and KennyP have said thanks
#18 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 19, 2013 - 06:42 PM
I finished the repairs.  Below is the pic of one side at the axle tube mount...the other side I did exactly the same.
This is at the cross member at the front of the transaxle housing.  John Deere only had the one bolt utilized.  The hole was worn oblong, so I used this large hardened steel washer and welded it to the plate after taking this pic.
The cross member passes right over another tapped transaxle boss on the other side, so I drilled the plate so I could add another bolt to this side.  The red arrow points to the added bolt.  Only one I had the right length was a used one.
  Being I raised the transaxle at the axle mounts 1/4", I also had to add spacer washers at the front, marked by the blue arrow.
Took her for a drive, and the problem is GONE!!!!!!!!   :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:
I now also have a positive neutral, with NO creeping!
  • Texas Deere and Horse, KennyP and twostep have said thanks
#19 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted February 19, 2013 - 07:01 PM
Looks like a good fix to me, Daniel! And it sounds like it worked. That's the best part.
  • olcowhand said thank you
#20 Robert Webb OFFLINE
Robert Webb
  • 930 Thanks
  • 436 posts
Posted February 19, 2013 - 08:34 PM
Daniel............is that YOUR 430 or your Brothers?
#21 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 19, 2013 - 08:37 PM
It's mine Robert.  Very happy I got this repaired!
#22 Cvans ONLINE
  • 7,310 Thanks
  • 6,392 posts
Posted February 19, 2013 - 08:51 PM
Congratulations on the repair. When things start floating around life can get kind of squirrely.
#23 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 20, 2013 - 11:37 AM
Got the deck back on & ready for Spring mowin!
#24 mowinman2 OFFLINE
mowinman2
    Always on the Hunt
  • 199 Thanks
  • 243 posts
Posted February 20, 2013 - 11:52 AM
Glad you were able to get it fixed so quickly, and no neutral creep is a great added bonus!!
#25 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 23, 2013 - 11:30 AM
We are glad you got the major problem corrected, maybe JD should have you on there staff to tell them how to correct such problem for yours will last a life time, and using used bolts is what they are saved for. Good job.
Dick
#26 Cat385B OFFLINE
    HAZMAT CAT
  • 14,379 Thanks
  • 10,146 posts
Posted February 23, 2013 - 11:33 AM
If that tractor was red there would pics accompanying that declaration............... :tapping_fingers:
#27 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 23, 2013 - 12:39 PM
You're probably right!   :smilewink: .......I'll get a pic in a little while.  :D
#28 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted February 23, 2013 - 06:23 PM
I didn't get the 430 out for pics today.....sorry.
#29 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 01, 2013 - 04:59 PM
just a update , 420's and 30's are nothing like the 400 . i dont know what it would take to break the axle brackets on a 400 it would be tuff to do . anyhoo my bolts where loose so i pulled the bolts put a little blue thread lock on them and tightened them till they wouldnt turn and then went another 1/4 turn . ( old time torque specks ) LOL . no more creep in reverse and no more clunk when changing directions . happy happy happy
  • olcowhand and KennyP have said thanks
#30 geb63619 OFFLINE
geb63619
  • 18 Thanks
  • 20 posts
Posted April 16, 2013 - 11:58 PM
I did this wright up a while ago on another forum thought I would pass this along.
